F45 Switch Removal
First go to ratshack and get two packs of the following:
Wirewound Resistors
271-132
10 watt 10 ohm
They look like a small block of clay with a siver wire on each end, two to a pack.
Underneath the car at each shock location there is a blue connection for the wire running from the shock. The wire does not unhook at the shock but if you trace the wire you will find the connector. Disconnect the wire there.
Take a pair of wire cutters and cut the wire as close to the shock as possible. You will be left with the bare wire on one end and the original connector at the other end.
There are two wires inside of the black covering, and with wire and a black wire. Remove the covering from these as well to expose the two bare wires.
Solder the resistor in between the two bare wires to complete a circuit. This will fool the computer into thinking the F45 Shocks are still there as the ocmputer looks for the resistance. I used some water prrof silicone after the solder then wrapped it in duct tape.
Repeat for all four shocks. Reconnect all four wires at the blue coneection back under the car.
You will be good to go.
