Grind/groan in differential.
Old Feb 9, 2009 | 01:08 PM
Cirrus8's Avatar
Cirrus8
Default Grind/groan in differential.
My 2001 At developed a grind/groan in the differential during a tight turn in either direction. I thought that I would choose the simplest possible fix so, I changed the diff lube with new Mobile 1 LS in the recommended weight and VOILA --- the noise went away!! Since I had to have the axle seals replaced twice, I have to assume that the Limited Slip additive was not replaced by the dealer. My Vette has 21K miles on the clock.
