HID fog problem
Old Feb 9, 2009 | 05:22 PM
Dougzilla's Avatar
Dougzilla
Default HID fog problem
Anyone have a suggestion what would cause one fog light to burn and the other not ? I have checked the wiring, swapped the hid bulbs and replaced the ballast. The driver side lit up once and will not come on now. The passenger side works as advertised. I have troubleshot everything possible and I'm stumped.
Old Feb 9, 2009 | 06:11 PM
ENJ's Avatar
ENJ
Doug, Are the wires reversed on the drivers side? I had to reverse the wires on mine to make the drivers side operate.
Old Feb 9, 2009 | 06:55 PM
Dougzilla's Avatar
Dougzilla
I don't think they are back wards. When i first installed they both worked fine for a couple of days. Then the drivers side wouldn't come back on. I got the drivers side to fire off one time after the ballast change.
Old Feb 9, 2009 | 08:37 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I'm guessing you already checked the fuses?
I have Hellas BTW.
Old Feb 10, 2009 | 12:11 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Are you running a relay harness or just plugged into the factory wiring?
Old Feb 10, 2009 | 09:20 AM
THE TECH's Avatar
THE TECH
Could be just a cheap set of HIDs.
Old Feb 10, 2009 | 10:00 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
If you're not running a relay harness, you need to. There are several aftermarket HID kits out there that get cranky if they don't get a huge startup surge.
Old Feb 10, 2009 | 10:06 AM
Turbopower87's Avatar
Turbopower87
Any recomendations for a relay harness? And maybe how to install one?
Old Feb 10, 2009 | 12:46 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
if you order a pre-built one, it usually costs around $20. Or you can build your own for about $10.
installation is easy just mount the positive lead, ground lead then plug the connectors into the correct sockets. The hardest part is deciding on a place to mount the relay itself.
Old Feb 10, 2009 | 05:10 PM
Dougzilla's Avatar
Dougzilla
Thanks for the info everyone. Right now Im running the stock wiring, but I have a harness waiting to install. Waiting for it to get a bit warmer.
To HID fog problem
