40 Below
Old Feb 9, 2009 | 09:01 PM
midlifetoy1's Avatar
midlifetoy1
Default 40 Below
Has anyone used this stuff? It's said to lower temps. I checked the label and it calls for you to drain the radiator and use this stuff with only water. Just looking for opinons
Old Feb 10, 2009 | 08:41 AM
mikeco's Avatar
mikeco
Active Streak: 90 Days
I've tried it and didn't notice any difference.I do like Redline's Waterwetter.I use it in my rods & it seems to work.
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Chip
__________________
..................Click for
Old Feb 10, 2009 | 10:00 AM
Twospeed's Avatar
Twospeed
That stuff is expensive. I used it as directed. Didn'y really change anything except it made my wallet lighter !
Old Feb 10, 2009 | 10:02 AM
Sinister-one's Avatar
Sinister-one
Old Feb 10, 2009 | 03:34 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
What is car now?
How old is Dex mix?
Are you stock?
What temps are you worried about?
The stock Dex-cool mix is due to be changed out/replaced at 5yr.
Everything else being stock and an A4-then Id just take enough mix out of the expansion tank to add 2 bottles of Waterwetter. It will help it run cooler at the top end. If your seeing higher temps in traffic and they come down when you get moving-your OK.
Also check out the under side of radior-these bottom breathers suck up leaves and plastic bags
Are the fans cycling on/off OK?
Old Feb 10, 2009 | 04:02 PM
midlifetoy1
Default 40 Below
Originally Posted by Oldad
What is car now?
How old is Dex mix?
Are you stock?
First, thanks for all replies...
Car is 02 vert and basically stock; just varram and hypertech handheld tune. fans are reprogrammed to cycle on sooner. Dex mix will be 2 years in spring. I'm concerned about 225 plus temps, as car is a DD and sometimes sits in traffic. Last summer, I saw 250 on occassion, did go down after extended 60 plus driving. Will be checking rad this weekend w/oil change. Even this winter, with outside temp in the teens, temp reached 200 plus.
Old Feb 10, 2009 | 05:56 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
200 is not hot!
If your running 225s in traffic and its coming down on its own when you get moving. Your OK. Still look under and vaccum up under where the radiator amd condensor come together.
Old Feb 10, 2009 | 08:27 PM
rrichar2591's Avatar
rrichar2591
200 is not hot!
I run 200 plus most of the time. The car was designed to run at those temps. I think your normal!
Old Feb 10, 2009 | 10:27 PM
canyon lake corvette's Avatar
Ive used it before and sold it many times, I last used it an a blown mustang, old school one where we used to think that 200 was overheating. It did lower temps on that car, I also did a comparison against wateretter and found it to work slightly better.
To 40 Below
