Quick question Z06
Old Feb 9, 2009 | 11:21 PM
lwise4's Avatar
lwise4
Default Quick question Z06
i sold a guy my 2002 Z06 this week "Thursday". He drove it 100 miles and the engine started making a racket and quit. The car had 11,573 miles on it when I sold it. He had it towed to a Chevy dealer and they told him a valve spring had failed.
he researched the internet and found a similar problem with another Z06 owner. Was or is this a common problem with the 02 Z06?
Old Feb 9, 2009 | 11:49 PM
Indy's Avatar
Indy
You should probably post this in the Z06 section. They will know
Old Feb 9, 2009 | 11:57 PM
bartsky's Avatar
bartsky
Yes very common failure.
Old Feb 10, 2009 | 07:28 AM
dieseldave56's Avatar
dieseldave56
Default Ah yes the LS6 valve springs.......
Yes with the introduction of the new reduced diameter base lobe LS6 camshaft (.550-inch lift, highest lift cam ever installed in a GM production engine to that date) came the new valve train i.e. longer sodium filled valves and striffer 400 Newton ( 90lbs closed) valve springs. The open spring rates increased from 1150N ( 259lbs) to 1310N (294lbs) on both .The Rockwell or hardness of the springs became an issue with higher sustained rpms. The spring's material is a little more brittle than the LS1.
Long story short, yes Virgina there are reports of broken springs on '02-'03 LS6 engines but appears to me to be aggressive driving style that induces the problem.
Old Feb 10, 2009 | 01:04 PM
Last C5's Avatar
Last C5
"Long story short, yes Virgina there are reports of broken springs on '02-'03 LS6 engines but appears to me to be aggressive driving style that induces the problem.[/QUOTE]"
Sound like the new owner may have been trying it out a little too aggressively.
Old Feb 10, 2009 | 03:08 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
That really sucks both ways.
My guess is he over reved the engine and/or missed a gear!
Old Feb 10, 2009 | 04:47 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's was a problem on some 2002's. I just hope the valve and pistons did not collide.
Unfortunately, mechanical things fail and if the timing had been a few miles off when he picked up the car from you it would have happened to you.
Old Feb 10, 2009 | 04:48 PM
lwise4's Avatar
lwise4
Default Spring failure
When he called me right after the failure, He was in a panic state. Understandable sinc He only had the car one day. He initially told me He was driving through a construction zone behind a truck and was in third gear. This was on the interstate! At the end of the zone He accellerated around the truck and all hell broke loose.
His initial call indicated that the plugs had disintegrated and since He stated plural I assumed Diesel in the tank. However after teardown, it was determined that a single valve spring had failed!
This car was owned by a sixty plus woman originally and when I called Her and mentioned that I was putting on a skip shift, She said that if I needed that I was driving too fast. Soo I am pretty sure She babied it and I know I did so why did the spring fail?
The Z06 was my 10th Vette dating back to my first in 1965 and I have never had a engine problem even with more agressive driving in my younger days. He seemed to have a problem shifting when He test drove the car, could a missed shift have caused the spring failure?
Old Feb 10, 2009 | 05:00 PM
bartsky's Avatar
bartsky
Regardless of how he was driving, the spring breaking is just common to this year LS6 so it is just very unfortunate timing for the buyer.
Old Feb 10, 2009 | 05:09 PM
JohnStuttle's Avatar
JohnStuttle
Do Not Quench The Spirit
St. Jude Donor '13,'19 thru '26
My guess - missed shift on a speed shift - been there done that - john
Old Feb 10, 2009 | 05:16 PM
tommie's Avatar
tommie
sorry to say this, but it is his problem not yours, i know it sucks for him, but the only way that you could be to blame, would be if you had just installed the valve springs or had recently done top end work, and you did something that caused the valve spring to break.
but from the sound of it, you had not done any internal work to the engine, i think he probably over reved the engine or missed a shift like stated above and caused the problem....
Old Feb 10, 2009 | 06:05 PM
stig-zzz's Avatar
stig-zzz
plus his story has changed sounds like driver error to me
Old Feb 26, 2009 | 07:53 PM
twobit's Avatar
twobit
Default shi.......
had a valve spring brake on me this week. #5 cylinder exhaust side.
03 z06 18,000 mi. driving 45 mph and then upper end noise.i hope i did not bend a valve.
Old Feb 26, 2009 | 08:05 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
damn, that's terrible timing for the buyer.
I agree that it's not your problem... but, from the tone of your posts it sounds like you're making some effort to help the buyer anyway, and that is very commendable!
To Quick question Z06
