View Poll Results: Should I upgrade to braided brake lines?
Yes
21
80.77%
No
5
19.23%
Voters: 26. You may not vote on this poll
Braided lines
Old Feb 10, 2009 | 07:35 AM
Lancejoker's Avatar
Lancejoker
Default Braided lines
Hey guys,I'm working on getting the order together for my brake upgrade and I wanted to know what your thoughts on braided lines were. Would love to hear all opinions. From my understanding,they get rid of the spongey feeling which is exactly what I'm looking for. Thanks everyone.
Old Feb 10, 2009 | 10:05 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Old Feb 10, 2009 | 10:51 AM
billla's Avatar
billla
St. Jude Donor '14
If your brakes are "spongey", I'd start with fluid replacement and bleed before looking at lines.
I'll also throw out there that braided lines take you out of SCCA Super Stock if you ever autcross the car.
Old Feb 10, 2009 | 10:56 AM
ljthe2nd's Avatar
ljthe2nd
I put them on my car when I put on Z06 calipers, drilled and slotted rotors and ceramic pads. I didn't notice any difference at all. But I did this swap when the car only had 5k miles on it so there wasn't any sponginess to the pedal. If I had it to do over again I probably wouldn't put them on.
Old Feb 10, 2009 | 11:14 AM
Lancejoker's Avatar
Lancejoker
Guess I should add that this is a daily driven street car that will see an occassional show. Nothing more. Track time isn't even a thought.
Old Feb 10, 2009 | 12:05 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
My black car has the OEM lines that are eleven years old and about 67K miles on them. I'm going to replace them with the Goodrich lines, not so much because of the sponginess of the pedal, but more because they are old and with the Phoenix heat, it's just a good idea.
You also might consider upgrading to a DOT4 fluid and a power flush of the system to get all the sediment out of the system at the same time.
Old Feb 10, 2009 | 01:12 PM
Lancejoker's Avatar
Lancejoker
Anyone here experience any problems with them? Leaks or things of that nature?
Old Feb 10, 2009 | 01:23 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Goodrich S/S brakes lines are a must have on any C5 or C6. Very well worth the hundred or so bucks.
You'll have a much more responsive feel and they are also well protected from debris cutting a line...
Old Feb 10, 2009 | 01:54 PM
bucwheat's Avatar
bucwheat
Default hood liner
Who has the best price on a new C-5 hood liner? anyone get a new one recently?
Old Feb 10, 2009 | 01:55 PM
bucwheat's Avatar
bucwheat
I have no idea how this got posted here,it was supposed to be a new post!
Old Feb 10, 2009 | 02:05 PM
EStreeter's Avatar
EStreeter
No problems if you install them correctly. If you don't do them right, the SS braided covering can chafe the inner hose - not good.
They are pretty easy to install. Can't say I felt any major difference but my car only had 38K on the clock when I replaced the pads and added the SS lines at the same time. Stock lines were still in good shape.
Old Feb 10, 2009 | 02:12 PM
Mistakes happen. Try Gene at gmpartshouse.com but be sure to check the shipping too. It just might be cheaper to get one from your local dealer.
Old Feb 10, 2009 | 04:07 PM
Lancejoker's Avatar
Lancejoker
Just wanted to say thanx to everyone for their input.
Old Feb 10, 2009 | 04:33 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Your brake pedal is probably spongy because your brake lines are old and the rubber is starting to give.
I like the VBP brake lines myself. They give a nice firn brake pedal feel.
Old Feb 10, 2009 | 09:17 PM
Lancejoker's Avatar
Lancejoker
Vbp?
Old Feb 10, 2009 | 09:40 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Vbp?
http://www.vbandp.com/detail.aspx?ID=75
Old Feb 10, 2009 | 09:47 PM
DefenderC5's Avatar
DefenderC5
I installed SS lines when I did my caliper swap at 65k. I noticed absolutely zero improvement during normal driving. I noticed some moderate improvement during high speed/heavy braking where I could better modulate the pedal when it was closer to the floor. IMHO, I'd just put your money elsewhere for a DD car. There was some "sponginess" before, and it was there after too.
To Braided lines
