extream road noise
Old Feb 11, 2009 | 01:28 AM
larryazbill's Avatar
larryazbill
6th Gear
Default extream road noise
I just purchased 2000 targa top but I need help on eliminating road noise. I'm getting rid of the G.Y. run flat tires but I heard that there may be an insulation pad that can be installed in the cargo area. Can anyone help?
Old Feb 11, 2009 | 07:26 AM
LTCHAPPA's Avatar
LTCHAPPA
Getting rid of the GY runflates is a good idea,then remove all the carpeting in the cargo area and line with something like dyna-mat to help cacel out road noise.
Old Feb 11, 2009 | 10:11 AM
Kale's Avatar
Kale
dynamt isn't a noise barrier, it's a dampening material.
you could line the interior with foam, and then a layer of lead. that might do it. Ora product called 'luxury liner'. But any real sound barrier material is going to be very, very heavy and expensive.
Getting rid of the run flats will make the biggest difference.
Old Feb 11, 2009 | 10:13 AM
fixvet's Avatar
fixvet
Basically, you just have to remember you're driving a sports car.....not a Cadillac luxury cruiser! You'll never get rid of all the noise. I've driven mine across the USA 3 times, and I like the sports car sounds!!! Especially my Z06 catbacks when they really get warmed up after cruising at 80mph for about 3 hours. It doesn't get any better for me!!
Do some forum searches........there are ALOT of threads here about installing sound insulation products.
Old Feb 11, 2009 | 12:43 PM
Before you go to the expense of a sound barrier, try different tires first. Might just make one heck of a difference.
Old Feb 11, 2009 | 03:58 PM
Cordes Performance Racing's Avatar
Supporting Vendor
tires help a ton! so did the tunnel plate upgrade.
Old Feb 11, 2009 | 07:27 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
You'll be amazed at how much of a difference non-run flats will make.
Old Feb 11, 2009 | 07:50 PM
JEEP/C5's Avatar
JEEP/C5
I did the "frost king mod" (do a search on it - tons of treads) along with 3 wedge packs of dynomat extreme front and back and I am very happy with the results. Its not hard to do your self (look at some write ups on this) and only cost me around $100 total. This along with new Non run flat tires you will see a major difference. I also realized a much cooler cabin in the summer!
JRP8704's Avatar
JRP8704
Get rid of the run crap$, and turn up the tunes and roll!
Old Feb 11, 2009 | 08:18 PM
Bu La'ia's Avatar
Bu La'ia
I put ContiExtremeContacts on mine............. LOVE IT
It nocked the road noise down to nothing, well except when driving on I-5 and 217 in the Portland metro (those darn people that use studded tire have made channels in each lane).
Old Feb 11, 2009 | 08:37 PM
Dave concrete's Avatar
Dave concrete
If you go to Tire RACK .COM you can put your tire size in and all tires in your size will come up and you can read the ratings on the tire choices.
Old Feb 11, 2009 | 11:26 PM
Black C5 Z06's Avatar
Black C5 Z06
Get a softer tire and you'll be golden. That's alll you need to do
If you still have wind noise, make sure your weatherstripping doesn't need replacing.
Old Feb 12, 2009 | 12:17 AM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
All of the above, then turn up the stereo! It is a chevy!
To extream road noise
