Need Help car shut off
Old Feb 12, 2009 | 10:32 PM
shvlhead's Avatar
shvlhead
2nd Gear
Default Need Help car shut off
02 Z06 with 415 C.I.D, intake, cam, exhaust, tune. I had a hiccup after driving a while on the highway around 2100 RPM. The hiccup feels like the car shuts off for a split second. This was going on for about 2-3 weeks. I had to drive the car in the rain on my way to work, 20 minute drive. On the way home from work (it was dry and had stopped raining) and my car just shut off. It wouldn't start for 10-15 minutes and then I tried again and it started up. This happened 3 times on my 20 minute drive home. I was low on fuel but not at reserve fuel yet and now the car doesn't sound as loud as it was. I think i've notice a vaccuum cleaner noise coming from the back of the motor near the firewall, not sure if it was there before or not.
I've taken it for a couple short drives since and it died once as i pulled into my parking spot.
Any ideas??
Old Feb 12, 2009 | 10:42 PM
Oldvetter's Avatar
Oldvetter
Pull up your codes using the DIC (search for this). This is always a good place to start when you have no idea.
Does noise sound like a vacuum leak? Maybe a vacuum hose came off or split open. This could make idle rough and stall out.
Old Feb 12, 2009 | 10:59 PM
shvlhead's Avatar
shvlhead
2nd Gear
I took it to advance and they said there were no codes.
Old Feb 12, 2009 | 11:23 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the PCV valve to intake connection tube. They can and will develop holes on the bottom of them out of sight...assuming the '02's have that?
To Need Help car shut off
