question on c6 wheels on c5
Old Feb 14, 2009 | 07:48 AM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Default question on c6 wheels on c5
I buddy of mine has a 99 C5, he wants to put C6 rims on it.
My question is will the 99 TP sensors from his wagon wheel rims fit in the newer C6 Rims?
Are there any other issues other than the sensors?
Thanks Guys.
Old Feb 14, 2009 | 08:26 AM
army2000's Avatar
army2000
St. Jude Donor '11
The TPS will fit with no problems.
Old Feb 14, 2009 | 09:18 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Just make sure he puts the sensors back in the same positions on the new wheels.
Old Feb 14, 2009 | 12:38 PM
my6thvette's Avatar
my6thvette
I would also be a good idea to replace the o-rings on the sensors. #9 o-rings from Lowes or Home Depot will work.
Old Feb 14, 2009 | 01:13 PM
ALLEGRO's Avatar
ALLEGRO
I agree with everyone's suggestions. Just follow them ALL. HOWEVER, if the TPMS sensors are old, you would be better off just purchasing new ones and start over. That's what I did.
Good Luck
Old Feb 14, 2009 | 02:09 PM
Mike Mercury's Avatar
Mike Mercury
Thanks Guys.
the front C6 rims are the same exact offset as the C5; but the C6 rears are a different offset than the C5 factory rims.
the C6 rear rims will sit inward when bolted up to the C5... around 7/16". About 50% that have done this rim swap have reported slight tire rubbing on the inner side of the fenderwell.
When I did this upgrade, I added those inexpensive 1/4" plate spacers the rears. Not as much for the rubbing concerns, but more for the cosmetics. And was still able to use standard lugnuts.
Old Feb 14, 2009 | 08:59 PM
kommon's Avatar
kommon
Cruising
Hi,
I am new to the board. I was wondering if there is a way to tune out the TPMS? My father has a 99 vette and I just want to turn them off as they are all failing and need to be replaced. Some people say yes, some people say no, I read somewhere that someone said a tech2 could turn it off. Any help would be greatly appreciated. Thanks
Old Feb 14, 2009 | 09:56 PM
bencini231's Avatar
bencini231
They will work fine but you will need o rings for the sensors and spacers on the rear wheels.
To question on c6 wheels on c5
