How to Question
Old Feb 14, 2009 | 08:47 AM
DARTH Z06's Avatar
DARTH Z06
1st Gear
Default How to Question
Good Morning All:
I have a question for a task I think I can do myself but am not for certain if I can or even should. I would like to 1) remove the side body molding strip on the doors and 2) I would like to remove the rear emblem on my decklid. Just from past experience I figured I would getting a blowdryer and try and re-activate the adhesive and then remove. I would then follow up with a fine cleaner wax. So the questions are:
1) Am I going about this the correct way or is there a better way?
2) Is this something I should let a p&b do for me?
3) Since the car is black with there be any color diffence when I remove the strips and emblem?
Any and all advice from those who have done this would be greatly appreciated.
Thank you
Old Feb 14, 2009 | 09:13 AM
Carcass's Avatar
Carcass
I've seen some posts in the past on this,and I believe people have used fishing line to cut the adhesive under the BSM's and the emblems.
Not sure if a blow dryer is also used -
You might try a search for BSM Removal to find out more.
Old Feb 14, 2009 | 09:29 AM
Vega$Vette's Avatar
Vega$Vette
Blow dryer heat it up fishing line or even dental floss tripled up use a sawing motion as you apply gentle up pressure it will come right off. A little goo gone for the remaining adhesive an polish it up NO PROB
Old Feb 14, 2009 | 11:44 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
As far as the BSM go.
What I did was I bought a heat gun at Lowes and got some fishing line.
Heated up the side molding and then started using the fishing line in a saw effect working my way front to rear, It took all of 2 hours from start to finish and that included cleaning with goo B Gone and wax, You have to make sure your car hasn't been repainted , If it has you might have a color change under the bsm. Take your time, Don't rush things at all or you will cut into the bsm..
Bill K
Old Feb 15, 2009 | 08:22 PM
C5Bagger's Avatar
C5Bagger
I dont have the BSM, but I was wondering why some guys want to remove it. Does it become discolored? or start to peel? Or just want it off. Just curious.
Old Feb 16, 2009 | 12:24 AM
c5blkvetteguy's Avatar
c5blkvetteguy
I took my rear emblem off and there was no color change on my black car. The front emblem has two ***** that goes into the body. If you take the front emblem off, you will be left with two holes.
Old Feb 16, 2009 | 01:00 AM
intoc6s's Avatar
intoc6s
Me too! I like the look of the BSM. When did they start putting them on C5s?
Old Feb 16, 2009 | 01:15 AM
happiedazs's Avatar
happiedazs
I believe there is a solvent you can buy that disolves the adhesive ---- go to an auto paint store and ask them what solvent to use
Old Feb 16, 2009 | 02:07 AM
Myalterego's Avatar
Myalterego
3M makes an adhesive releasant that can be found at most automotive paint and body shop supply stores.
Old Feb 16, 2009 | 03:15 AM
AMRAAM's Avatar
AMRAAM
It's simply a matter of taste. I personally like them, but many don't. It is actually one of the most debated topics on this forum.
Old Feb 16, 2009 | 03:22 AM
Wethingtonvette8093's Avatar
Wethingtonvette8093
Yeah its a personal preference thing, I like them tho.
To How to Question
