HID 6000k vs 8000k Pic Request
Old Feb 16, 2009 | 01:26 AM
Polar Jet's Avatar
Polar Jet
Default HID 6000k vs 8000k Pic Request
Just when I think I've decided I have doubts.
I'm ordering HID conversion kits for both the low beams and the fog lights on my 02 C5. I have a feeling that the 6000k will be my choice but I just need to see some more pics of both to be certain.
Thanks!
Rob
Old Feb 16, 2009 | 01:36 AM
vettegator005's Avatar
vettegator005
how much is the total swap going to run you?
Old Feb 16, 2009 | 01:37 AM
DefenderC5's Avatar
DefenderC5
6000k here. I found it to be the closest to white during the night and day without looking blue. It has a very very slight blue tint at night. 8000k is too blue IMO. The bulbs are in a standalone projector.
Old Feb 16, 2009 | 02:39 AM
Turbopower87's Avatar
Turbopower87
I had 8000k in my Mazda 3 and the light output was worse than the stock halogens. It had projectors too so I would imagine it would be even worse in the vette.
I bought 5000K for my vette and I'm still not as happy as I thought I'd be. I'll probably end up with some depos or make my own projector set up sometime down the road.
So my advice is 6000K if those are the only 2 you are considering
Old Feb 16, 2009 | 02:47 AM
Polar Jet's Avatar
Polar Jet
I'll know exactly when I place my order on Tuesday. I'm guessing about $225 Canadian for both kits shipped to my door. I calculate that to end up being about $5000 US based on where our dollar is at!
Somewhere around $300 US range I figure.
Old Feb 16, 2009 | 04:31 AM
Hams's Avatar
Hams
Cruise-In VII Veteran
I have the 6000 look great, and I can see a lot better. Hams
Old Feb 16, 2009 | 05:27 AM
jdmvette's Avatar
jdmvette
Night Owl for life
6000k is what i use in my c5.
8000k is much too blue in my opinion.
this is 8000k (formerly in my other vehicle, so i have first hand knowledge) projected onto a white parking lot marking.
see how strong the blue tint is?
Old Feb 16, 2009 | 09:59 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Another Vote for 6000K. 4300K looks like a flashlight, 5000k glares off everything (even in a quality OEM projector) and 8000K is so blue it distorts the reflective image. 6000K HIDs produce ~2900 lumens of visible light per bulb while 8000K produce 2400 lumens.
IMO 6000K is perfect. (it's the same color as a standard white LED) Here's a few examples:
35w HID D2S 6000k in Hella H9 90mm retroed projectors:
35w HID H9 PNP in Hella H9 stock projectors
My car: 55w D2S 6000K in E55 Bi-xenon w/ ZKW replica lenses:
note: this picture was taken about an hour before sunset
Old Feb 16, 2009 | 10:40 AM
diyguy's Avatar
diyguy
Old Feb 16, 2009 | 11:23 AM
2004SpiralGrey's Avatar
2004SpiralGrey
6000k low beams and fogs with LED turn signal bulbs
Old Feb 16, 2009 | 11:31 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Another vote for 6000K's. They are more "white" than others I have seen. 8000K's on my friends car look blue to me. If u want that then thats cool. Its all about what you like.
My 6000K HID's and 6000K Fog Lights. (stock housings)
Toque
Old Feb 16, 2009 | 12:57 PM
vettegator005
where did you get the led turn signal bulbs?
Old Feb 16, 2009 | 01:23 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Hope this helps..
Old Feb 16, 2009 | 01:54 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
What kind of housing are you using? Is it stock or ACA (per your Avetar)?
Old Feb 16, 2009 | 06:39 PM
jrprich's Avatar
jrprich
I like 5000k......but I agree that 6000k is as high as one should go. Otherwise just too much light output is lost
Old Feb 16, 2009 | 11:41 PM
2004SpiralGrey
Autolumination.com
Old Feb 17, 2009 | 01:20 AM
InSaNeKaMeL's Avatar
InSaNeKaMeL
simple if ur under 26 go 8000k if ur older go 5000-6000k
To HID 6000k vs 8000k Pic Request
Old Feb 17, 2009 | 03:44 PM
Polar Jet's Avatar
Polar Jet
Thanks for the advice all. Based on your opinions and that of the vendor I am purchasing from I've decided to go with the 6000k version.
Maybe I am too old (37) and too pro domestic to go above that!
Old Feb 17, 2009 | 03:51 PM
vettegator005
haha very good point
Old Feb 17, 2009 | 04:40 PM
MG RED 99's Avatar
MG RED 99
Using the ACA projector housings with 6000k bulbs. I'm actually contemplating installing the 4200k bulbs the kit came with. I like the look of the 6000k, but might want a little more light output, which the 4200k would provide. definitely would not go with the 8000k, not nearly enough light output.
6000K shown in picture
