Question about Powder Coating...
Old Feb 17, 2009 | 01:37 AM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Default Question about Powder Coating...
I don't have (knowingly) anything that's powder-coated. What exactly IS it? Does it leave a rough surface or a smooth one?
I saw a member here a while back who powder-coated his Z06 wheels a bright silver. Looked amazing! If I were to have that done... how would I clean them? Does powder-coating chip or flake? Is it pretty permanent and durable?
Thanks for any replies!
Old Feb 17, 2009 | 03:31 AM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
Powdercoating will leave a smooth glossy surface. You would clean them like you clean anything else...actually they may be easier to clean as stuff doesn't seem to stick the powdercoat as easy as it does to other surfaces.
From what i can tell, powdercoating won't chip or flake and is damn near indestructible.
Old Feb 17, 2009 | 05:55 AM
dieseldave56's Avatar
dieseldave56
Default Power coat properties
http://www.powdercoatingonline.com/h...teristics.html
Old Feb 17, 2009 | 06:53 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I've got several things powdercoated on my car and it's extremely durable amd easy to clean.
Old Feb 17, 2009 | 10:11 AM
kerryt1's Avatar
kerryt1
It's a powdered pigment applied with an electrostatic charge. It's then baked, and fuses into a hard coating. If done right, it's very durable and chip resistant. The finish is smooth (if the underlaying surface is smooth), but not quite as glossy as paint.
Old Feb 17, 2009 | 10:31 AM
Xx_Black-out's Avatar
Xx_Black-out
St. Jude Donor '08-'11-'12
Powdercoating is very chip resistant and super easy to clean...
I have my Z06 wheels done in a "Tex Black". It is a semi-gloss look, so you don't have to get the "gloss black" look.
Feel free to PM me...
-Nick
Old Feb 17, 2009 | 05:14 PM
Alaskanpilot
thanks for the replies everyone! Very helpful.
I think I'll probably end up getting my rims powdercoated silver. I think the stock argent gray is okay... but bright silver rims really pop against a black car.
Anyone know a ball-park price on the cost of powdercoating rims?
Old Feb 17, 2009 | 05:26 PM
Purerock105's Avatar
Purerock105
Similar to me. I have the C6/QX1 or Comp Grey wheels powdercoated black.
Old Feb 17, 2009 | 05:32 PM
hotwheels57's Avatar
hotwheels57
It can fade from UV rays. I had the fencing to prove it.
It can chip, although it's pretty tough, more so than regular paint. I had two complete chassis, suspension parts and engine bay components to prove it.
It can be degraded by some chemicals. I had engine components to prove it.
It can be touched up with regular paint should it get chipped, but it probably won't be an exact match. Your best bet is to have the powder coating shop provide you with a closely matching aerosol spray touch up paint.
The powder coating will only be as good as the base preparation and experience of the person applying it.
It can look amazing on a set of wheels or anything else, but it isn't impervious to anything "thrown" at it.
Old Feb 17, 2009 | 05:38 PM
kingsey's Avatar
kingsey
My rims are getting powdercoated as we speak
Old Feb 17, 2009 | 11:56 PM
dieseldave56
Default shine , durability depends.........
Depending on the type of resin used determines how the shine will be and how durable and UV resilient the finish will be. http://www.powdercoatingonline.com/h...teristics.html
Old Mar 11, 2009 | 10:00 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I charge 300 plus shipping for stock rims, 100 extra for clearcoat, (required on silvers). Powdercoat is a polyester plastic resin that melts and is much more durable than paint.
Old Mar 11, 2009 | 11:06 PM
fireman591's Avatar
fireman591
Mike does awesome work
Here is a picture of a caliper he powdercoated for me
To Question about Powder Coating...
