inside door handle bezel question....
Feb 17, 2009 | 05:26 PM
St. Jude Donor '21
these plastic bezels on inside of door around the door handles, are they the same? or is there a left and right? I don't see a difference...
Feb 17, 2009 | 05:30 PM
There is a left and right. Look at the back side,they are marked.
St. Jude Donor '09-'10
I need to order one.. anyone have a part #? It's for the passenger door, it must've fallen out at some point.
Feb 17, 2009 | 08:23 PM
St. Jude Donor '21
I've looked , no such marking, and I see no difference in these bezels?
Quote:
Originally Posted by
LTCHAPPA
Feb 17, 2009 | 08:35 PM
St. Jude Donor '08-'09-'10
When you say "near the door handle"...
do you mean the door handle from which you pull the door closed;
or the door handle you pull to open the door?
Something tells me you might be thinking of the little plastic caps that go behind the door pulls... little oval caps that are 3" by about 3/4"?
Or do you mean the large, molded bezel around the door HANDLE that you open the door with?
Generally it's the former that people are always losing and not noticing. They are not marked L or R, and those ARE the same.
Feb 17, 2009 | 08:41 PM
St. Jude Donor '21
Alaskanpilot
door handle that OPENS the door...the plastic bezel around it (I need just 1)
Feb 18, 2009 | 06:06 AM
St. Jude Donor '21
