[Z06] skip shifting question
Old Feb 20, 2009 | 04:22 AM
Ltrain925's Avatar
Ltrain925
Default skip shifting question
i have my skip shift deleted but when im cruising around and not getting on it i try to go from 1-2-4-6 especially getting on the freeway to save wear n tear and less work, when going from 2nd to 4th it takes a good push to get it in 4th or from 4-6th as where if i go from 2nd-3keeping the clutch in and going to 4th it goes in much easier obviously because the syncros are better lined up(same with 4-6th but hitting 5th to line them up). my question is does it matter how i do it, is it easier on the tranny if i just go2nd to 3rd then to 4th to line the syncros up vs 2nd to 4th or does it not matter. i figured it wouldn't since these cars came with the skip shift but i just thought i'd ask.
Old Feb 21, 2009 | 02:01 AM
striper's Avatar
striper
Once in a while, if I'm in traffic and not going too fast, I might shift 1-3-5 and then 6 if it gets fast enough. It seems to go smoothly and maybe saves a couple of ounces of gas.
Old Feb 21, 2009 | 08:19 AM
Bigstik's Avatar
Bigstik
Exactly what I do and it doesn't hurt the tanny at all. I even go 2-3-5-6 sometimes. 1-4 was a bit of a leap though.
Old Feb 21, 2009 | 09:40 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I do the same thing in mine most of the time. 2-4-6. 2-4-5-6.
Old Feb 21, 2009 | 12:33 PM
dbaker's Avatar
dbaker
I drive the Interstates alot.I usually accel to speed 1-2-3-4,skip 5 and shift to 6.Around town,I'll stay in 5 so the car won't bog.
\db2
Carolina
Old Feb 21, 2009 | 12:36 PM
hattitude's Avatar
hattitude
When I skip shifts, I don't notice any difference in effort between gears.
Old Feb 21, 2009 | 01:20 PM
B-ras's Avatar
B-ras
I go 1-3 or 2-4 sometimes around town. I find I have to slow the shift down, specifically the engagement of the higher hear, in order to be smooth. It makes sense; there is more of a differential in RPM between the gears when you skip, so you have to allow the revs to fall. The effect is probably exacerbated by my short shifter.
To skip shifting question
