[Z06] will this X pipe bolt on?
Old Feb 20, 2009 | 03:34 PM
kessler89's Avatar
kessler89
Default will this X pipe bolt on?
thinking about getting this and then getting my car tuned, will it bolt on inbetween the stock manifolds and the factory Ti catback?
http://cgi.ebay.com/ebaymotors/97-04...1%7C240%3A1318
Old Feb 20, 2009 | 03:54 PM
THE TECH's Avatar
THE TECH
Sounds like it should. You'll have to have some flanges welded on though it looks like.
Old Feb 20, 2009 | 11:28 PM
Ryan L's Avatar
Ryan L
You aren't supposed to weld anything since it has a slip fit design. Pretty much all aftermarket x-pipes require you to cut some of the stock mid-pipe off.
Old Feb 21, 2009 | 12:07 AM
MTPZ06's Avatar
MTPZ06
It will bolt right up with some minor cutting of the stock mid-pipe. Bassani's x-pipe is one of the better designs out there, and that's a real good price. I say go for it.
Old Feb 21, 2009 | 02:21 AM
striper's Avatar
striper
Bassani products are good quality. The only thing I would change is the clamps used on the front section, the ones supplied crush the pipes and will make it difficult to remove should the need arise. I would get double-wide band clamps, which are sold at NAPA and other stores, Summit has them too. They seal better and are removeable and reusable. If you are not doing any other exhaust mods they will make it quieter than it is now. Also, the amount of hp increase is quite minimal so I'd probably save my money. The tune is worthwhile, but if you've done nothing else I don't think I'd even bother with that. If you're ever considering doing a header install, most headers would supply the rest of the exhaust system which would include the x-pipe. LG Motorsports has a complete "street" system which they frequently put on sale. It includes long tube headers, high flow cats and x-pipe section, all in polished stainless steel. It runs a little over a thousand dollars for the whole system and with a tune can add a considerable hp increase and a terrific sound. People have gotten more than a 30 hp increase with this complete system. I have it on my car and love it! Just my 2 cents.
To will this X pipe bolt on?
