Kwiklift Experience
Old Feb 21, 2009 | 11:27 AM
retiredsfsgm's Avatar
retiredsfsgm
Default Kwiklift Experience
Looking into the potential purchase of a Kwiklift. Anyone with some first hand ownership experience with this unit ? Easy to use ? Quality ? Vendor support ? Any comments/input much appreciated.
Retired SF SGM
Old Feb 21, 2009 | 11:35 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
they work well. You will still need bottle jacks if you are taking off the wheels, but not a big deal.
Old Feb 21, 2009 | 02:37 PM
Choreo's Avatar
Choreo
Very well built. Excellent vendor support. Easy to use - especially if you leave it assembled.
I have a special case where I am using it on a tiled garage floor, so I took some extra steps to add rubber casters and some stacking blocks where I could store it when I don't need it. Most people leave theirs completely assembled and you can also lie it flat and park on it when not in use - I just did not want to go that route. The way mine is set up, it takes me 10 minutes by myself to set up and tear down (less if I did not have a tile floor to protect).
A two or four post lift would be better in most cases, but there is the added expense and it is ALWAYS in the way when not in use. If you have a 6-car garage they are a dream, but for me I just needed something that was strong, safe, and somewhat portable. Highly recommend.
Old Feb 21, 2009 | 03:17 PM
DsC5's Avatar
DsC5
Old Feb 21, 2009 | 05:30 PM
kerryt1's Avatar
kerryt1
It's a little more work than pushing a button to raise the car, and it only gets the car up to 20" at the bottom of the tires.
That said, I've done a ton of fluid changes, installed an underdrive pulley, and just today lowered my C5Z and my buddy's C6. I lay it flat and just park on top of it.
I highly recommend it as an alternative to a four post lift.
Ultimately, however, there is no replacement for a two post hydraulic lift.
Old Feb 21, 2009 | 05:59 PM
Kale's Avatar
Kale
Mine is great. My only regret is getting "dark blue" which more closely resembles "baby blue"
Old Feb 21, 2009 | 06:11 PM
Vette-kid's Avatar
Vette-kid
Man I want one of these so bad! Its just not real high on the priority list right now...buts its high on the WANT list Looks like it would be great for those of us who move often.
Old Feb 21, 2009 | 06:42 PM
1FUNVTT's Avatar
1FUNVTT
I agree ... if a 2 or 4 post lift will work in your garage, get that instead of a Quik Lift.
In my case, neither lifts would work, so I purchased a Quik Lift. No regrets; used it many times and my corvette buddies like it too. Make sure your floor jack has the raise height of at least 21 inches, so you can set the lift’s rear stands.
The Quik Lift has the perfect height if you’re using a creeper – you can roll under the car and it’s not too high to be a nuisance. Low enough, so when my hood is opened, it’s not hitting the ceiling. The only draw back to this lift system is the added steps you need to take when you want the wheels off.
Definitely a safer way to raise a car higher without setting it on blocks of wood and as the name says: Quicker too.
Old Feb 21, 2009 | 08:14 PM
71corv's Avatar
71corv
St. Jude Donor '08
Works good. Used my son's lift to install my headers.
Gene
Old Feb 21, 2009 | 10:33 PM
Fast Cop's Avatar
Fast Cop
I have had mine for about 2 years now. After looking around I knew (due to height of garage) I was not going to be able to get a full size lift and the Kwik Lift was exactly what I needed.
I am in the middle of LG long tube header install this weekend and the lift is a big help!!!
Old Feb 22, 2009 | 01:50 AM
Z06ster's Avatar
Z06ster
Unfortunately, it will be a little while before I get one of these, but its definitely going to be in my future.
Old Feb 22, 2009 | 02:11 AM
YNOT2K's Avatar
YNOT2K
at a fellow forum members garage this morning i saw my first kwiklift. nice, but the prices have evened out and for the same money he spent on his i could alomost get a 4 post lift. check out the prices and compare...
take it easy,
jeff
Old Feb 22, 2009 | 02:17 AM
SJPD's Avatar
SJPD
I'd rather have a scissiors lift.
Old Feb 22, 2009 | 06:38 AM
guppie's Avatar
guppie
St. Jude Donor '08
I like mine a lot, would have a 2 or 4 post lift if I had the height in the garage though.
It does need skid tape of some kind on the middle rail, if the tires are wet they will spin. I bought a 4"x60' roll from Graingers it fits perfect on the middle rail.
I also made a platform out of wood to be able to use a floorjack from the side to remove the wheels if needed.
To Kwiklift Experience
