Well I changed two of my tire pressure sensor batteries in my 1999 coupe today and it was a snap. I used a small flat screwdriver to scrape off the epoxy and a pick set for the tight spaces. A paint can opener works great to pry the battery off the double sided tape.
here are the steps I took
Make a line like I did on the back side. That line gives you plenty of room to expose the solder pads
Using a small screwdriver slowly filet the small layer of epoxy.
Take your time and work around the battery with the screw driver and pick set
Once the area around the battery has been removed Cut the exposed battery lead and gently pry up the battery with paint can opener around all sides except for the solder joint side.Once the battery is loose cut the lead on the bottom
Once the battery is out take your time and clean up the battery box area. be careful around the board area.
Remove old battery leads with soldering iron and add a fresh bead of solder to each contact.
Fold the positive lead onto the side and inset the battery positive down and line up the soldering points with the battery leads. Trim the negative lead as needed. I trimmed off 2-3 MM on mine.#8
Solder the leads, test them with a volt meter for safe measure and cover with a thin layer of hot glue. My old batteries were in the 2.89-3.02 volt range and the new ones are in the 3.44-3.48 range.#9
Fill in all nooks and crannys with silicone and smooth with a blade or putty knife. You are done Tools and parts used
pick set
tube of silicone
hot glue gun
solder and solder pen
putty knife or razor blade
paint can opener (prys up old battery awesome)
The first one took about an hour to do and the second one took 40 minutes. it was a piece of cake. I can't wait to do the other two.
Hope this thread helped
Fireman591
Nice work.
It does seem ridiculous to be held hostage for what should be a simple fix/replacement. I feel especially bad for people with the older version.
Nice work.
I agree! There was no way I was going to pay over $400.00 for TPS
This was a very easy job. You just need to take your time and be careful around the board. These things are built to take a beating so changing a battery will make them just like new again
2 down 2 to go
I did mine for a 1997 it was a snap.Batt was a p030-nd from Digi-Key.Also if you don't have a volt meter you can train your sensor before you install it to see if it works.
I will be retraining it tomorrow also
I can't do it today cause I am on duty
