Wheel question...
Old Feb 21, 2009 | 09:57 PM
darbn's Avatar
darbn
Default Wheel question...
Do these wheels have the right offset or will they stick out?
18x9.5 with a +57mm offset and 18x10.5 with a +58mm offset
Old Feb 21, 2009 | 11:39 PM
Russ K's Avatar
Russ K
Those offsets will be perfect, and the tires won't stick out. I recommend 265/35/18 & 295/35/18 tires for your car.
Russ Kemp
Old Feb 21, 2009 | 11:57 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Russ Kemp
Good advice above.
Old Feb 22, 2009 | 02:20 AM
darbn's Avatar
darbn
Thanks for the advice guys.
Old Feb 22, 2009 | 02:55 AM
ljthe2nd's Avatar
ljthe2nd
They won't stick out but there might be a problem. The front will be fine, but the rear might rub on the inside.
The stock wheels for a coupe and a convertable are:
fronts 17 x 8.5 with a 58mm offset
rears 18 x 9.5 with a 65mm offset
wheel offset explained
http://www.fullsizechevy.com/forums/...explained.html
Old Feb 22, 2009 | 03:03 AM
jdmvette's Avatar
jdmvette
Night Owl for life
they're also an inch wider in the rear so they need to stick out a bit more, so the offset is lower.
Old Feb 22, 2009 | 03:46 AM
ljthe2nd's Avatar
ljthe2nd
I'm wrong you are correct, with a wider wheel you would want less of an offset, so the rear wheels will probably be ok, but the front are also 1 inch wider and they are about the same offset as a stock wheel so there is a chance the front wheels will rub on the inside.
Old Feb 22, 2009 | 09:24 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
18x10.5 - 58mm is the OE C5 Z06 rear wheel size.
It will fit like a stock wheel, because it's identical in size and offset to one.
Old Feb 22, 2009 | 11:06 AM
ljthe2nd's Avatar
ljthe2nd
I agree the rear wheel is fine, its the front that I think might be a problem. Maybe not but it will be about a 1/2" closer to the frame than a stock wheel and tire.
Old Feb 22, 2009 | 11:33 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The front OE Z06 wheel is 17x9.5" with a 54mm offset.
A 3mm difference here is so slight, (less than 1/8"), I wouldn't worry about it.
I base all my "correct fitment" calculations off the stock Z06 wheel dimensions, because they fit perfectly flush with the fenders and aren't tucked in so far like the C5 wheels are.
FWIW, (see my sig above), I am running 19x9.5" - 54mm and 20x10" - 52mm offset wheels. They were made to fit flush with the fenders exactly the same as the Z06 wheels do. There are no clearance issues whatsoever.
Old Feb 22, 2009 | 02:44 PM
ljthe2nd's Avatar
ljthe2nd
FWIW, (see my sig above), I am running 19x9.5" - 54mm and 20x10" - 52mm offset wheels. There are no clearance issues whatsoever.
If you are running those wheels with no problems, the wheels the OP want to use should be no problem.
Old Feb 22, 2009 | 04:28 PM
Those will work just fine. Good luck with the new wheels.
To Wheel question...
