after clear coat....then?
Old Feb 22, 2009 | 09:17 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default after clear coat....then?
I tried this in "paint/body". with not much help....
When painting interior dash pieces..ie: radio bezel, console, after all the sanding, color coat, and clear coats, is there something else that should be done? like wax and buff? with what?
Old Feb 22, 2009 | 09:30 AM
CRV3TT3's Avatar
CRV3TT3
If you want a nice smooth finish like the exterior of your car get some 1000 and 2000 grit sand paper and wet sand the clear coat starting with the 1000 and finish up with the 2000. When youre done sanding get some rubbing compound and rub it out till the shine returns to the paint (5-10 minutes) after that clean it with some 91% alcohol to make sure you have cut into the paint and not just filling it. if it comes out good hit it with some carnuba wax and youre done!!
Old Feb 22, 2009 | 09:38 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
WAIT JUST A MINUTE....you want me to SAND this clear coat???
Yikes! I thought the sanding process was DONE!
Shows you what I know....I think I'm scared to sand this....it took too long to get it where it is!
Old Feb 22, 2009 | 10:08 AM
CRV3TT3's Avatar
CRV3TT3
It'll be worth it trust me!!! soak the paper for about 30 minutes prior to starting and go slow and youll be thanking me later!
Old Feb 22, 2009 | 10:18 AM
bucwheat's Avatar
bucwheat
also you might get you a spray bottle and fill with pure water to keep the surface wet.
Old Feb 22, 2009 | 10:44 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Oh yes. That's why you wet sand with 1000 grit. It's not as course as 400 grit so it won't hurt the finish as long as you keep it wet and watch what you're doing. Follow up with the rubbing compound just like noted above. Post some pics when you're done.
Old Feb 22, 2009 | 12:43 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
These pieces are pretty shiny and smooth right now...not sure I have the **lls to scratch this up!
Old Feb 22, 2009 | 01:14 PM
Konstantin's Avatar
Konstantin
it is easy to screw up, specially if it is your first time. so if you're going to do it, be prepared to start all over again. not to discourage you, but i've screwed up before and now just dont have the patience to do things like that anymore.
Old Feb 22, 2009 | 01:17 PM
JW Motorsports
Banned Scam/Spammer
If you are happy with it then leave it alone. It's not worth messing it up when you like what you have.
Old Feb 22, 2009 | 01:25 PM
Lowcash's Avatar
Lowcash
That's the fun part about DIY projects. Doing your own paint and sanding requires a lot of patience and time. If you sand through the clear, you just have to re-do it.
I sanded through the clear a couple times on my interior pieces. I got it right eventually. Afterwards I machine polished, waxed and buffed the pieces.
Old Feb 22, 2009 | 02:04 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
I'm thinkinh they're gonna be fine the way they are...
what kinda of wax did you use these?
Old Feb 22, 2009 | 02:29 PM
Lowcash's Avatar
Lowcash
I used NXT because that is what I had handy at the moment.
Old Feb 22, 2009 | 10:38 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
If you're going to wet sand clear, make sure you have at least 3 good coats of clear or the risk of sanding through the clear is very high.
Also, you can wetsand with 1500 and then 2000. Don't worry about sanding every spot perfect, just hit 75% and then start buffing. rubbing compound 1st, then a polishing compound, then a swirl remover, the a glaze.
Just a little labor! Enjoy.
Old Feb 22, 2009 | 11:41 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Damn, I gotta get me a vert!! that is stunning!!
Old Feb 23, 2009 | 12:23 AM
travelingypsye's Avatar
travelingypsye
I agree with all above except........DONOT wetsand the clearcoat until it has dried well. 1 week (7 days) after it is applied. Also do not use wax on the finish for 90 days. this allows the paint/clear to "cure". If not, there is a possibility of the finish becoming cloudy in the sun or spider cracks to appear as the paint tries to cure & not able to breath under wax. Polish is different. Polish allows for the paint to breath. No body shop uses wax to rub out clear coat finishes. 3M finnese polish or hand glaze works well, Meguiars #2-5 or hand glaze also is good.
Old Feb 23, 2009 | 05:42 AM
dougbfresh's Avatar
dougbfresh
You can wetsand the next day with modern paint no problems-I do it, body shops do it the same day sometimes. You'll need a small buffer like one of the Meguires ones to do this stuff, a large bonnet buffer will not get into the areas you have and you run the risk of launching your work like a missle with a big buffer if you hit it wrong. If your clear layed out smooth, I'd leave it alone-if you have alot of Orange Peel I'd wetsand and buff. You should PRACTICE on some test pieces FIRST-it's an art to do it and not burn sharp edges, you need to get used the the buffer your going to use or you WILL have problems.
To after clear coat....then?
