fast 90 and tb hp difference??????
Old Feb 22, 2009 | 12:48 PM
thehawkjr's Avatar
thehawkjr
Default fast 90 and tb hp difference??????
Would it be worth the money to get a fast intake and tb. Would I notice the difference? I have lg pro long tubes, off road x,corsa pace,vararam,callaway wires and ac delco plugs and tune.. How many mm is a stock 97 tb...??
Old Feb 22, 2009 | 02:52 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I would pass unless you plan on head/cam work. You'll see some gains with the 90/90 combo, but it's mostly a supporting modification to more in-depth engine mods.
I believe your stock tb is 78mm. A ported or aftermarket throttle body will net you miniscule amount of power, but give you significantly improved throttle response. However it will also make the throttle more sensitive.
Old Feb 22, 2009 | 03:50 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I agree that a 90/90 combo is an overkill and on a stockish/bolt-on type motor you would not see much gain--you would however benefit if you do hds/cam with the 90/90--but for the money I still think it's not worth it-- My opinion would be for you to go with a LS6 manifold as your '97 still has the LS1 intake--For the price you can't beat this upgrade--The LS6 is an excellent intake--Take a look at this intake comparison--realize that it is on a hds/cam motor but the results are relative---also the larger manifolds you'll see that they make all their HP up beyond 6400---so with a stock cam you are not getting the full benefit as a stock cam quits making power around 5800-6000 RPM's
http://tpis.com/index.php?module=2_17_06
Old Feb 22, 2009 | 07:01 PM
thehawkjr's Avatar
thehawkjr
thanks guys that help a lot and good looking out on the website about the intakes.. thanks....Zack
To fast 90 and tb hp difference??????
