Do you run at 30PSI? If not, why?
Old Feb 24, 2009 | 01:01 PM
  #41
corvettepete's Avatar
corvettepete
My stock Eagle run-flats start out at 30psi cold and usually go up a couple psi as they warm up.
Old Feb 24, 2009 | 01:37 PM
  #42
evowake's Avatar
evowake
Originally Posted by Indy
On the inside of the drivers door there is a sticker with the correct psi for tires...follow that. That should be the ideal pressure for street use. Indy
Old Feb 25, 2009 | 11:59 AM
  #43
Nightdrv's Avatar
Nightdrv
For Me:
31 Front
29 Rear
Old Feb 25, 2009 | 12:05 PM
  #44
bucwheat's Avatar
bucwheat
I keep mine around 32, if the DIC isn't flashing at me I'm happy.
Old Apr 29, 2009 | 03:36 PM
  #45
AfterburninC5's Avatar
AfterburninC5
Cruising
Originally Posted by Joel Forman
Same thing happened to my rears using 30 PSI cold.....wore out OEM runflat Goodyears in the middle in 29,000 miles. Now I set all the tires for 28PSI cold.
Me too...28 cold or about 30 hot all around.
Old Apr 29, 2009 | 03:53 PM
  #46
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
On the street I run 30 PSI cold all the way around. On the race track I ran 38 PSI hot.
Old May 1, 2009 | 08:11 AM
  #47
RSchleder's Avatar
RSchleder
I run my Pilot Sports ( non- runflats) @ 28 lbs. I don't drive the car too hard though.
Old May 1, 2009 | 11:29 AM
  #48
7898VETTMAN's Avatar
7898VETTMAN
Any idea on 295/35/18 kdw's cold? I had em around 28psi and rode terrible.Now at 36psi cold and feels better but I am still unsure if this is good.
Old May 1, 2009 | 12:00 PM
  #49
bahn112's Avatar
bahn112
Originally Posted by JJS04
I was actually going to ask the same question. I just put new tires on mine and the tire shop put 40psi in the rear. Seems a bit high to me.
depends on the size of the tire you threw on there. i wouldn't just answer with a blanket "it's too much".
i use to run 40 PSI on 265/35/22's on my old 05 chrysler 300 and the truck i traded in on my vette was running 45 PSI on 285/70/17 MT's as this was an accepted safe pressure when driving on city/paved roads (obviously much lower when taken off-road).
Old May 1, 2009 | 12:01 PM
  #50
bahn112's Avatar
bahn112
oh, as for my vette, i'm running 30 psi cold on 265F/295R firestone wide ovals.
Old May 1, 2009 | 12:02 PM
  #51
bucwheat's Avatar
bucwheat
30 to 32 is where I stay.
Old May 1, 2009 | 12:04 PM
  #52
BenC5's Avatar
BenC5
Based on all I've read on here, I keep my stock 01 C5 wheels with stock sized Falken FK452's at 30 psi F/R.
I do notice on the DIC, the pressures go all the way as high as 37 when it is hot on the highway, anyone else notice this?
Old May 1, 2009 | 12:54 PM
  #53
jedblanks's Avatar
jedblanks
I tend to run all my tires within 10% of their max PSI rating. I don't mind the rough ride and like the longer tire life + added gas mileage.
As they get older sometimes I will run them at recommended pressures (lower) to get better traction and finish off the outer edges of the tread.
Sometimes tire shops will over inflate so the new tires won't flat spot and the bead will seat better. I usually leave them over-inflated for a day or two.
Old May 1, 2009 | 01:04 PM
  #54
30 psi is the correct pressure according to the sticker on the inside of the door. That's what I keep mine at and they wear very evenly.
Old May 1, 2009 | 02:25 PM
  #55
c5vetteman99's Avatar
c5vetteman99
i try to keep them between 34 and 38 psi
Old May 1, 2009 | 04:31 PM
  #56
kettemr's Avatar
kettemr
Originally Posted by Smoky2
I inflate 'em to 30psi cold. Then I'm running they get up to about 34 or higher.
I like the ride and handling at this pressure.
Old May 1, 2009 | 06:24 PM
  #57
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
If the DIC is happy, so am I
Old May 1, 2009 | 10:30 PM
  #58
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
That's how mine reacts, inflated cold, 30psi, and even with the heat we get down here, I have never noticed any of them running above 35psi, and that's been during the heat of the day, around 80ish-mph on a 50-60 mile run. And tires are wearing evenly.
Old May 1, 2009 | 10:32 PM
  #59
Kappa's Avatar
Kappa
30 cold. I'll raise or lower it at the track, depending on which type I'm at.
