Positrac Question
Old Feb 23, 2009 | 08:14 PM
rkink's Avatar
rkink
Default Positrac Question
I notice when I make a slow tight left hand turn around in my '97, the front tires seem to "push" or slip a bit on the marbles. Can this be caused by the posi clutches not releasing properly? I just realized that I haven't tried a right turn around.
Old Feb 23, 2009 | 10:17 PM
c5blkvetteguy's Avatar
c5blkvetteguy
You just need to push the right pedal down about half way.
Old Feb 23, 2009 | 11:00 PM
ALLEGRO's Avatar
ALLEGRO
Could be several things. Here are the most likely two:
1. Could be worn clutches. Maybe more worn to let the right wheel free up when turning right, more tension while turning left.
2. Also, could be that you need to change the diff fluid and make sure you add the correct amount of friction modifier.
Keep us posted.
To Positrac Question
