coolant change???
Old Feb 28, 2009 | 10:49 AM
sorbet70's Avatar
sorbet70
Default coolant change???
my 02 c-5 has 14k on it, should i change?and is it hard to do?the dexcool in the reserve tank looks clean.........thankyou in advance
Old Feb 28, 2009 | 10:55 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Nope. Sounds like no need at this point.
I'm not exactly sure about the mileage measurement, but I was told 100K "at least" ---
Old Feb 28, 2009 | 11:44 AM
DexCool is good for 100K miles or 5 years, whichever comes first. If it were my car, I would be changing the coolant. Probably do a radiator flush along with it.
Old Feb 28, 2009 | 12:01 PM
MyVetteDream
Originally Posted by 8VETTE7
The rule for coolant change is NOT just 100K miles. It's 5 years or 100K miles which ever occurs first.
Good to know. Thanks!
Old Feb 28, 2009 | 01:25 PM
YELLO1's Avatar
YELLO1
C5 of the Month 5/13
Old Feb 28, 2009 | 02:32 PM
sorbet70's Avatar
sorbet70
thanks for the reply.........looks like a coolant change for me...........
Old Feb 28, 2009 | 02:46 PM
Vega$Vette's Avatar
Vega$Vette
With only 14K on it ....Take a look at the fluid. If it still has the original color (or close to) not brown or muddy looking then just leave it alone.
The manufacture's spec is 5 year because they are trying to sell more. It does not go bad sitting in the engine and unlike cast iron blocks you're not getting any rust contamination.
Old Feb 28, 2009 | 08:01 PM
dobewillie's Avatar
dobewillie
if in doubt change it
Old Feb 28, 2009 | 08:18 PM
Nick1's Avatar
Nick1
Do yourself a favor after doing a search on this.
Get the "other" drain valve, the one with the tab on it. It will come in handy should the crummy stock one break, and on future changes.
Old Feb 28, 2009 | 08:21 PM
GrandSportRob's Avatar
GrandSportRob
Change it! Your car is 7 years old..My 99 only has 35k miles on it and I plan another change in a month...I'm going by the 5yr rule..NOT MILEAGE...Did it once in 04 so it's time again..
Old Feb 28, 2009 | 09:09 PM
robsc501's Avatar
robsc501
Hi There:
I changed the coolant on my 01 vette at 6 years.Coolant was very clean & no temp. problems.I,am looking in my log book 6/14/07 12,434 miles. A few months later I changed clutch fluid , brake & tranny fluid.(all the fluids were factory) The brake fluid & tranny fluid were dirty.I only noticed a change in the transmission. The shifting was a lot smoother & no notchyness going into 1st gear(6spd.) No change in the braking of the car.
If you are worried about the coolant.You can do a refracto meter test.
Put the black lead on the batt. negative cable & the red lead into the coolant.You should see a 0.20 volt reading or less, if higher flush & change the coolant.
robsc501
Old Mar 1, 2009 | 11:37 AM
sorbet70's Avatar
sorbet70
i agree,i just checked the tank again today and the coolant is clean..nice orangeeeeee red
To coolant change???
