Any one using 13.35" BAER rotors on the front with non stock wheels? If so any issues????? I am going to pull the trigger and was wondering if they will fit my CCW wheels.
Love to see some pics if you have them.
Fred
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by SearayC5
They will fit stock 17s so I think there shouldn't be a problem.
I don't think so. The stock rotors are 12.75" and the above rotors he is talking about is 13.35".
This is what Baer told me directly when I asked if Baer kit PN 2301053 has the 13.35" rotors with the brackets to move the calipers outward. I had already told him that I have 19" wheels in the front now.
Baer said in reply:
You are correct ! The 2301053 would be the correct number for your Corvette. These will not fit the factory wheel but looks like you have that handled.
Fred
Fred:
I should have pictures by Monday of how the 13.35" rotors look behind my Front 19" CCW SP500's....
I was told that no modification is needed with the 19" CCW's and the 13.35" up front. Guess I'll find out soon.
I would think that a 18" or 19" CCW up front would have no issues with the 13.35" Baer rotors.
The rear 14" needed some massaging to work with the 3" lip CCW's
Toque
Here is how the 14" looks behind my 19" Rear CCW SP500's
I have the Baer EradiSpeed 2-piece front and 1-piece rear rotors installed on my 2004. The stock 5-spoke rim fit over with no modifications as well as the Ace Slick Hyperblack rim. I would like to move into a set of CCWs 505As and am curious as well whther they will fit over these rotors without spacers or adjustments.
Your fronts must be the 12.75" stock sizes right ? Not the upsize 13.35" ?
Toque
That was fast delivery on your rotors. I e-mail them and have not heard back. I am looking forward to seeing yours completed. I have been following you on the rears and expect no problem once i grind down the rear calipers. I have CCW 505As 19" all around.
