97 TPM sensor on z06 wheels
Old Mar 1, 2009 | 03:57 PM
texict's Avatar
texict
Default 97 TPM sensor on z06 wheels
It is time for new tires and maybe wheels. I have been reading that there are different TPM for 97-2000 and 2001 - up for C5's. Did GM just change technology, or does it have anything to do with larger wheel sizes or anything like that?
I would like to put z06 size wheels on my 97 and want to make sure I can still use my existing sensors? After further thinking while I type this, I assume I would have to use my current ones or the receiver might not pick up the signal.
I have also seen that the the battery life was planned for about 10 years and the the 97-2000 TPMs are are 3 times as much as for the newer c5's. Should I replace my exisiting ones? Are there good aftermarket solutions?
TIA. This forum is awesome for someone like me who does not know much!!!
Old Mar 1, 2009 | 06:19 PM
slvr bulit's Avatar
slvr bulit
i switched from 98 stock wheels to stock z06 wheels and had the tire place switch my sensors to the z06 wheels. I have had no problems and have been running them for 2 years now. knock on wood
Old Mar 1, 2009 | 06:57 PM
INaband's Avatar
INaband
CI 7-8 Veteran
use your 1997 sensors, I did.
Old Mar 1, 2009 | 07:13 PM
dobewillie's Avatar
dobewillie
leave em till you need em
Old Mar 1, 2009 | 09:20 PM
Corvette Don's Avatar
Corvette Don
May be a good time to send your sensors out for a rebuild. WAY cheaper than buying new. Turn around time is one day.
http://shop.jwmotoring.com/product.s...4&productId=39
Old Mar 1, 2009 | 10:16 PM
Your '97 sensors will work in the Z06 wheels - and yes, you will need to stay with the '97-00 style sensors.
Old Mar 1, 2009 | 10:26 PM
jrose7004's Avatar
jrose7004
Jacks right!
Old Mar 1, 2009 | 11:44 PM
texict's Avatar
texict
Thanks to all!!!
To 97 TPM sensor on z06 wheels
