[Z06] Underdrive pulley?
Old Mar 4, 2009 | 10:28 AM
Z-Stallion's Avatar
Z-Stallion
Default Underdrive pulley?
For those that have installed it, did you notice any difference? Performance gain? Pros or Cons. I'm planning on having a cam, pulley, & LT headers installed pretty soon. Is there anything else that I should & should not do? Any advice is greatly appreciated. Thanks & have a great day!
Old Mar 4, 2009 | 11:50 AM
kerryt1's Avatar
kerryt1
I noticed that my crank pulley wasn't wobbling anymore. It will be off anyway for the cam install, it'd be stupid not to change it out. I have and recomend the Powerbond unit. It's a nice piece.
If you're ever going forced induction, nitrous, or the like...have the crank pulley / crank snout pinned.
Old Mar 4, 2009 | 12:10 PM
slothy's Avatar
slothy
if he ever does go FI he'll be removing that UD pulley anyway for stock dia or OD one.
Old Mar 4, 2009 | 02:30 PM
Z-Stallion's Avatar
Z-Stallion
So no need for the underdrive pulley if I decided to supercharged or turbocharged? Thanks
Old Mar 4, 2009 | 02:32 PM
slothy's Avatar
slothy
nope, you'll be spinning the s/c slower with a ud pulley, as for turbo pretty sure a ud pulley would give you benefits still its not belt driven.
Old Mar 5, 2009 | 12:11 AM
ls1impulse's Avatar
ls1impulse
What gains can be expected of a 25% underdrive? Also, are there any negatives to this in the Z06? Charging systems, headlights etc. will still function correctly?
Old Mar 5, 2009 | 08:04 AM
NemesisC5's Avatar
NemesisC5
Old Mar 5, 2009 | 03:22 PM
CarBoy's Avatar
CarBoy
Something to consider when doing a cam or heads or both. (and there is mixed opinions on this) Seriously consider putting in some SVO 30# injectors with your proposed upgrades. You can pick a full set up new for about $250.
Old Mar 5, 2009 | 05:32 PM
jpandes's Avatar
jpandes
When having my cam install done, my tuner said that an UD pulley could give me ~9 rwhp.
Old Mar 5, 2009 | 05:51 PM
ptindall's Avatar
ptindall
I have one. No negative side effects for me. It runs very true and does not throw my belt as apposed to the stock pulley that wobbled and did throw my belt.
To Underdrive pulley?
