CAGS Question
Old Mar 5, 2009 | 12:22 PM
stilfast's Avatar
stilfast
Default CAGS Question
I put a CAGS bypass on about 4 months ago. Last week I went down to Tuson, hit triple digits a couple of times (120+). When I started up to go home got the code P0803. Well the CAGS resistor got fried or the connection is loose or dirty. I did use a zip tie to fasten it up. I know I can buy another CAGS unit and/or refasten and clean the existing unit. My question is I know you can tune out the CAGS. But I don't want to spend $$$ for a tune just to do that. The only mods I have done are GHL bullets and the zip-tie air intake. Is there a cheap tune I can have done to eleminate the CAGS? Thanks as always for your help.
Old Mar 5, 2009 | 12:47 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Old Mar 5, 2009 | 12:49 PM
poolboy's Avatar
poolboy
I may be wrong, but I thought this could be disabled using the Tech II tool that the service guys use - I'm not sure that's the same as a tune though - more like shuting off an option in my mind....
and I don't unbderstand why high speed would fry it - you may want to talk to the place you bought it - sounds defective to me
Old Mar 5, 2009 | 01:39 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
You can have it tuned out. You can get a mail order tune from Chuck and Corvettes of Westchester. You can not believe the difference it will make. Money well spent and all you have to do is mail him your PCM.
Give Chuck a call at 914-332-0049
Old Mar 8, 2009 | 01:27 AM
buckster's Avatar
buckster
Predator Diablo hand held tuner will do it
Old Mar 8, 2009 | 10:45 AM
rws.1's Avatar
rws.1
search for a DIY.. the resistor can be bought at Radio shack for under $1
Old Mar 8, 2009 | 11:15 AM
KCJeff's Avatar
KCJeff
I experienced the same problem (same code). Ended up just replacing the CAGS bypass unit. For $20, it just wasn't worth the time to rebuild the unit. Some manufacturers version of CAGS bypass have had problems with resistors failing.
Old Mar 8, 2009 | 11:29 AM
Rossi396's Avatar
Rossi396
If you want to go the route of tuning it out, I don't think you can beat the price that ECS is offering...$149.00. Tune is also "unlocked." Not sure, but I've heard other vendors lock their tunes...
Old Mar 8, 2009 | 01:31 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
We can turn CAGS off for you, and give you a real dyno-tune for $500. If you simply want to have CAGS turned off - I'm sure we can just turn it off for a very nominal fee. Give me a call tomorrow and I'd be happy to get you a price on exactly what you want!!
To CAGS Question
