That is how much the transmission shop wants to charge to replace the seal between the transmission and the rear differential on my C5 since it was leaking, they also mentioned that the pan also had a leak, and since they are going to remove the tranny because it was a tight space to work on, they will be replacing the filter as well. all I can say is ouch on the price but I didn't have any choice -I believe that going to the dealer would've been more expensive.
See if there is a local Vette performance shop in your area and get a quote from them. It might cost that much because I think they have to drop the entire rear to get to it. Sorry I feel your pain.
Sounds a bit high. I believe the flat rate manual calls for 10 hours to remove and reinstall the driveline (yes, the entire driveline has to be pulled) and maybe another hour to replace the seal. At $75 per hour I wouldn't think it would be more than $1000 with all the extra charges (parts, shop materials, etc). As said above, I'd look for a shop more familiar with corvettes.
The dealersip paid $1200 to have a Chevy dealer fix mine before I bought it. They dropped the tube and rear assy to fix it.
So I guess it's not far off. What a pain to repair the seal. It's like murphy's law dropped the ball on me. This happened exactly 1 week after I put my car on the market for sale.
You say you believe the dealer would be more? How about asking them? I Have found the dealers in Phoenix to be fairly competitive on a lot of repairs.
Do it yourself... total cost, maybe $50 for gaskets and fluids.
I just had the exact same problem and I fixed it myself (with a friends help of course) It took 7 hours to do (First time dropping a corvette transmission) and it cost me $42. I think that 7 hours of my time was worth the $1158 in savings.
I paid about $1300 for dealership to do mine but i had them install 3.73 gears while they were in there since everything would be out anyway. They only charged an extra 900.00 for the gears setup and it eased the pain a little when I drove it after getting it back. AWESOME upgrade
Yeah thats fine giving that you have the proper tools,a place to do it, some mechanical know how,friends that can work with your time frame,and time in general. I have been taking apart motors,trannys and just about any car and heavy truck related project and for sure I would not lay under a vette and remove a diff. I did my exhaust on mine I really thought I was going to torch the car before I was done.
It's really only bad the first time, since everything is unfamiliar. I just pulled my drivetrain last weekend, my third time doing it. This time, I did it by myself, and took about 6 hours - working in my garage on jack stands, without turning the air compressor on. Other than basic sockets and wrenches, the only special tools you need are a transmission jack and a torque wrench. Making time can be tricky, but the wife is usually pretty accomodating when I tell her how much money it would cost for someone else to do it.
Wish I have the know how and the time - both of which are lacking,after the mechanic looked at -he wanted almost $2k because apparently the pan was shot as well but repairable, I told him to do his best with it, after all is said and done - $1690. Maybe I should've brought it to the dealer
Just took mine in for a code 1416 (check valve) issue and to have all fluids changed and get new brake pads and installed. I asked them to check on a small leak. I had seen about 20 drops or so after sitting for about 5 weeks this winter. They told me it would be $1400 to replace the seal. At least they are helping me out some since I am a loyal customer by doing all the fluid changes for ~$100 (oil, radiator, clutch, trans, diff) and giving me the pads for the same price as I could get them on gmpartsdirect.com. It's not a lot, but every little bit helps. He said he might can help me out a little more once it is all said and done. Wish I had the know how to do this myself. I know it is basically fear and maybe a few tools. I have done several things myself, like lowering, rotor/pad changes, plugs/wires, some intake stuff, short shifte installs, etc... but this feels a little over my head. Interesting that the dealership did all my fluid changes and the check valve replace before that told me about the seal.
I found a leak on my garage floor. Jacked up the vette myself, several of the pan screws were loose. Leaked was fixed. Seal was fine, over time the vibration will actually loosen the pan screws. Check that first.
TEN HOURS?! I can have it out in an hour and a half, in my garage, on my back, with HAND tools... Putting it back in takes 2, maybe 2 and a half and I do need a second set of hands to get it lined up. These places are ridiculous!
