[Z06] Changing fluids
Old Jan 26, 2002 | 05:36 PM
1953 C6's Avatar
1953 C6
Default Changing fluids
It's time to change my transmission and differential fluids. I'm looking for both directions and product advice. What parts are required? Magnetic plugs? Filters? Quantities? ATF? Redline? Mobil 1? Amzoil? Royal Purple? GM additive? Gaskets? etc.
Old Jan 30, 2002 | 08:38 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Default Re: Changing fluids (FRF Z06)
I researched this for quite a while and finally came up with exactly this: http://store.yahoo.com/corvetteforum/caumagdrainp2.html
Old Feb 1, 2002 | 07:14 PM
1953 C6's Avatar
1953 C6
Default Re: Changing fluids (Subdriver)
Thanks, I found that too. I was just waiting for some other opinions. Some heelpful tips on the process. You know. Frank
Old Feb 5, 2002 | 05:26 PM
Zrob's Avatar
Zrob
Cruising
Check out tech section on this site for info on diff fluid change. I just did it last week. I used Redline 70-90 synthetic AND the GM limited-slip friction modifier. I just used a 60cc syringe to fill it. It's very easy.
Old Feb 7, 2002 | 07:09 PM
1953 C6's Avatar
1953 C6
Thanks, I was all set for doing the swap to Redline until I found out it's not certified to meet GM's specs. So, I'm probably going to go with Amsoil???
Old Feb 7, 2002 | 09:01 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Amsoil for sure!!!!! :yesnod:
Old Feb 7, 2002 | 09:22 PM
VettTheRipper's Avatar
VettTheRipper
Default Re: Changing fluids (Glennm27)
I put Mobile 1 synthetic Dexron III in mine yesterday. It shifts a lot smoother and the tranny is quieter. And Mobile 1 is much easier to find and meets GM spec. :cheers:
To Changing fluids
