[Z06] Wipers gone crazy
Old Jan 26, 2002 | 06:36 PM
jeffsherman's Avatar
jeffsherman
Default Wipers gone crazy
Spent all morning cleaning and Zainoing the Z, go for a ride and the wipers kick on by themselves. Cant get the dmn thinks to shut off, so I stop the car and start looking for the wiper fuse. Then on a hunch I restart the car and the wipers shut off. 5 min later they go at it again, now I look really cool in a Z06 with beatiful weather and the wipers on - so I hit the washers to retain my dignity at least Im wiping something. Then they cycle off again. And so on and so on etc. Just turned 1k miles and I got my first Kentucky gremlin - Thank you General :U :U :U
Old Jan 26, 2002 | 07:09 PM
wstory1's Avatar
wstory1
Default Re: Wipers gone crazy (jeffsherman)
At least it's minor. Still disappointing though. :(
Old Jan 26, 2002 | 09:43 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Re: Wipers gone crazy (wstory1)
If you get water in the wiper motor it will short the wiper module and do this until it dries out.
Been there and done that on my '98 :bb
Old Jan 26, 2002 | 10:52 PM
jeffsherman
Default Re: Wipers gone crazy (RPO_Z06)
I hadnt thought of that I pulled the fuse but ill give a try in the am. Thanks for the tip, I didnt have any problems with my 2000 though
Old Jan 27, 2002 | 12:31 PM
HummelS's Avatar
HummelS
Also, if the BCM (Body Control Module) gets wet it can cause some pretty funky behavior - when my BCM went out (due to A/C condensation backing up) I could't keep the rear hatch closed. Even with the engine off, it would pop on its own. But I also got a lot of errors on the DIC, so if you're not seeing that, I'd suspect the motor.
[Modified by steve hummel, 8:32 AM 1/27/2002]
Old Jan 27, 2002 | 06:01 PM
jeffsherman
Hair dryer fixed the wiper problem, note to self get own hair dryer for tool box, wife freaks if you try to use hers. :U
Old Jan 27, 2002 | 08:03 PM
RPO_Z06's Avatar
RPO_Z06
Glad to hear your problem went away without a trip to the dealer. :yesnod:
Old Jan 27, 2002 | 08:51 PM
jeffsherman
Thxs for the input you hit the nail on the head :smash:
Old Jan 28, 2002 | 10:53 AM
jerryv's Avatar
jerryv
So now the question is .. where do we have to avoid spraying the hose in order to avoid mysterious electrical problems !!?
Old Jan 28, 2002 | 12:40 PM
jeffsherman
Default Re: Wipers gone crazy (Jerry Velders)
Avoid spraying onto the lower window at the drivers side, the wiper motor is directly below the driver's side wiper arm.
Old Jan 28, 2002 | 09:30 PM
jeffsherman
Default Re: Wipers gone crazy AGAIN DMIT (jeffsherman)
They started again at lunch today, :cry I pulled the fuse, the ride goes into the dealer on Wed this week, 1200 miles of trouble free driving, thanks GM :U
Old Jan 28, 2002 | 10:38 PM
RPO_Z06's Avatar
RPO_Z06
Aww, Man ! I thought you had it beat too. :(
Old Jan 29, 2002 | 11:34 AM
BlackZ's Avatar
BlackZ
Had this problem with my Ford Explorer. My wipers would come on for no
reason. The problem would go away for a couple of days and then return.
Took it to the dealer for a wiper motor replacement and it solved the problem.
To Wipers gone crazy
