targa top latch
Old Mar 7, 2009 | 09:28 AM
oldvetteguy99's Avatar
oldvetteguy99
Default targa top latch
Half of the rear latching mechanism is loose on the targa top The part that is concealed under the roof upholstery. Is this easy to remove without buggering it up, or should it be taken to a shop. This roof material is also starting to sag. Any ideas?
Old Mar 7, 2009 | 10:43 AM
Maites's Avatar
Maites
my headliner began to unstick and i took it off, then used gorilla glue to stick it back on... has not moved since
Old Mar 7, 2009 | 01:24 PM
oldvetteguy99
How did the headliner come off. Do you pry it up. are there clips. I don't want to mess it up
Old Mar 10, 2009 | 02:48 PM
Maites's Avatar
Maites
its glued on as one piece. The actual cloth was not sagging, the entire headliner was. There are no clips that hold it to the roof. Does that make sense?
Old Mar 10, 2009 | 02:49 PM
Maites's Avatar
Maites
I pryed it up!
To targa top latch
