Switchback LED DRL owners step inside [Pics]
Old Mar 8, 2009 | 11:04 PM
tracks03's Avatar
tracks03
I got a set of the 20's from Richard back in Oct. I just swapped one out with him because part of the white LED wouldn't light up or flicker when they did. He said he had 3 come back in a month with the same problem!
Sounds like there is a design flaw to these bulbs. Let us know if you experience the same problem with the 48's, JDM.
Old Mar 8, 2009 | 11:51 PM
SDuster11's Avatar
SDuster11
I agree with ColeTrain... Any pics of the switchback in a stock housing?
Old Mar 9, 2009 | 01:10 AM
ColeTrain'sC5's Avatar
ColeTrain'sC5
i had clear depo's but wanted to tint my stock corners(minus the area for the DRLs) and want to know if they'll be ok in a stock housing and bright still. If they are bright enough still i will for sure get them, especially since I'm going to be adding 6k HID fogs/lows this is how my stockers look...
Old Mar 9, 2009 | 12:52 PM
FreddyG's Avatar
FreddyG
Originally Posted by JMc
Just a guess, but I'm going to say those are 6000k HID fogs he's got in there...
Thanks! I thought so, but wasn't sure.
They look Great!
Old Mar 9, 2009 | 06:15 PM
VET IT B's Avatar
VET IT B
One side of my switchback DRL only is also out. They are about a year old +-.
Old Mar 9, 2009 | 06:21 PM
olftboy's Avatar
olftboy
I just ordered a set of 48's on Saturday. They were shipped today. I will post a pic of them in factory housings if no one else does before they arrive.
Old Mar 9, 2009 | 06:25 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Should I be concerned now with the 20's that I just received as part of my switchback package from Richard at Corvette Enhancements?? I prefer not having to pull these out in the next 1-2 years if at all possible. They aren't the easiest things to get to.
Old Mar 9, 2009 | 06:33 PM
csexton's Avatar
csexton
Good info
Chuck
ColeTrain'sC5
thank you SO much man. i REALLY appreciate it.
Old Mar 9, 2009 | 11:29 PM
tracks03's Avatar
tracks03
Tell me about it! It's so much fun dragging out the ramps, taking out all those screws...add to that, there must have been a mix-up at the warehouse, cause the first replacement I got was a 1157 style, not the 3157. Of course, I didn't pay attention to that until I had the old one out!
Old Mar 10, 2009 | 10:34 AM
JMc's Avatar
JMc
Hmmm... FYI, I was able to change my larger OEM DRL bulb out last year from a trick I learned on the forum. Basically, you remove the hood stop bolt in the front near the headlamp and it gives you enough room to reach your arm down there and get to the bulb. I'm not a small guy, either, but it worked and sure beats having to mess with ramps and all of that. My first attempt involved pushing the brake duct out of the way and reaching in through the front, but I actually got my hand stuck in that opening for awhile. Funny now, but "oh CRAP!" at the time...
Old Mar 10, 2009 | 11:33 AM
tracks03's Avatar
tracks03
Ah, I see. I didn't remove the stop bolt when I tried it from the top. How's the best way to make sure you put the stop bolt back at the right level? Mark it with a paint marker or a sharpie?
That brake duct there should be a simple way to get that completely out of the way. It was such a pain when I replaced the corner lenses, couldn't see anything, and had to feel what I was doing.
Old Mar 10, 2009 | 11:42 AM
  #33
JMc's Avatar
JMc
Naah, there is a nut that is threaded onto the bolt. Just make sure that nut stays in the same position as you remove the bolt and it will be in the same position when you tighten it back down.
Old Mar 10, 2009 | 12:03 PM
  #34
Sportsdude's Avatar
Sportsdude
I use it in my Hummer but it doesn't last long (5 months or less).
Old Mar 11, 2009 | 03:51 PM
  #35
VET IT B's Avatar
VET IT B
Any more news on the 20's being replaced with 48"s?
Old Mar 16, 2009 | 02:03 AM
  #36
c5mtl's Avatar
c5mtl
waiting on pics also
Old Mar 16, 2009 | 02:12 AM
  #37
ColeTrain'sC5
i PM'd him and waiting to hear back
Old Mar 21, 2009 | 02:32 PM
  #38
olftboy's Avatar
olftboy
Pics of stock housings with 48 led switchbacks now posted here >> http://forums.corvetteforum.com/c5-g...post1569386496
PM sent, ColeTrain'sC5
