Stock C5 CAM SPECS ???
Old Mar 7, 2009 | 03:45 PM
Scoops03's Avatar
Scoops03
Default Stock C5 CAM SPECS ???
What are the stock c5 cam specs?? Also, what do the numbers exactly mean? the Intake/Exhaust Duration, Lift, etc? I know what they "are" , but I cant remember what it all means exactly....one forum member briefly explained it to me, but i accidentally deleted the post.
Thanks guys!!
-Coop
Old Mar 8, 2009 | 03:20 PM
Scoops03's Avatar
Scoops03
Bump
Old Mar 8, 2009 | 03:49 PM
VetteRafa's Avatar
VetteRafa
Corvette ls1
...........pn Duration........Lift...............Lobe
97-99.....199/207.......0.472/0.479........117
00..........198/209.......0.500/0.500........115,5
01-03......198/207......0.467/.479...........116
Corvette ls6
01...........204/211.......0.525/0.525.......116
02-04.......204/218......0.555/0.551........117,5
Old Mar 8, 2009 | 07:58 PM
Scoops03's Avatar
Scoops03
Originally Posted by VetteRafa
Corvette ls1
Corvette ls6
Awesome!! Thank you!! I know what the lift means...but what does the duration and lobe mean?
Old Mar 8, 2009 | 09:13 PM
Turbopower87's Avatar
Turbopower87
Corvette ls1
Corvette ls6
What about my 04 LS1?
Old Mar 8, 2009 | 09:37 PM
slothy's Avatar
slothy
go on ls1tech and there is a huge thread on cam lingo
Old Mar 9, 2009 | 10:48 AM
jovette's Avatar
jovette
Same as '01-'03 LS1
Old Mar 9, 2009 | 10:54 AM
lil vette's Avatar
lil vette
Lift is amount valve is raised
Duration is amount of time valve is open
Old Mar 9, 2009 | 12:41 PM
Scoops03's Avatar
Scoops03
Thank you...but what about the lobe ? and im assuming that with the duration...the intake is how long its open for the ____ (air or gas?) and then the exhaust portion is how long its open for the fumes to get out?
Old Mar 9, 2009 | 03:04 PM
cammedvette's Avatar
cammedvette
I believe the "lobe" is measured as the angle of seperation between the the lobes.
Exp: 117 is 117 degree angle of seperation. Listed as 117 LSA (lobe speration angle)
Old Mar 11, 2009 | 03:15 PM
Scoops03's Avatar
Scoops03
Thanks guys!
To Stock C5 CAM SPECS ???
