Here are the offsets for the base and ZO6, provided by another member:
C5: STANDARD THIN SPOKE
Front 17x8.5 - 58mm
Rear 18x9.5 - 65mm
C5: Z06
Front 17x9.5 - 54mm
Rear 18x10.5 - 58mm
I can't imagine that a difference of a mm would matter, but definately, if one were changing wheel width, the offset should remain the same, meaning the center line was the same (a 1 inch wider tire would be 1/2 wider on the outside, and 1/2 on the inside).
Front 17x8.5 - 58mm
Rear 18x9.5 - 65mm
C5: Z06
Front 17x9.5 - 54mm
Rear 18x10.5 - 58mm
Ok, thanks. I realized when I was shipping the wheels back, that they said 56mm offset and I thought they were suppose to be 57mm offset. So that had me wondering. But then I figured it probably didn't matter much if they were off by 1mm. Just wanted to be sure though for the next set.
