Urethane Vs. Fiberglass
Borrowed from internet site:
* Fiberglass VS. Urethane
We're often asked about the difference between these two materials and which one is actually better. There are many factors to be considered in the answer to this question.
Overview of the Two Materials
Urethane is flexible but very difficult to customize or repair in any way.
Fiberglass is rigid but can be readily repaired or customized by a competent shop.
Points to be Considered
Purchase Cost
Fitment
Ability to Customize or Modify
Cost and Ability to repair
PURCHASE COST
If you are purchasing a quality part or kit, the urethane products are probably going to be slightly more expensive.
FITMENT
Generally speaking, a urethane product will fit a car slightly better right out of the box due to the control in the manufacturing process.
However, a urethane product CANNOT be fitted as exactly as a fiberglass part. Fiberglass products usually require trimming or filling during installation.
ABILITY TO CUSTOMIZE OR MODIFY
A good custom shop can modify or customize ALL fiberglass products. Fiberglass is a material that can be shaped, changed or fitted to any application. These mods can be reinforced to produce significant strength and durability. Urethane cannot be reworked or modified with any degree of durability.
COST AND ABILITY TO REPAIR
Urethane parts are flexible and will absorb very small 'hits' without creating serious damage (cracks or holes). However, once urethane is cracked in any manner, it is usually sent to the scrap pile out back.
Although our shop has perfected methods of repairing urethane parts, at best, the repair is temporary and cannot be guaranteed.
Fiberglass parts are totally repairable. Most damaged parts, within reason, of course, can be repaired by any shop experienced with fiberglass. Proper repairs on fiberglass parts are durable and should be permanent.
Let's look at a repair cost scenario on a full bumper replacement kit.
Suppose there are a couple of good sized cracks in the front bumper. Normally, with a urethane kit, the bumper will need to be replaced.
Usually, the part cost is approximately $425.00 + $125.00 (average) in shipping. The labor to remove/replace and paint will be a constant cost in either replacing or repairing. There will probably be a time delay of up to 4 weeks until the replacement bumper arrives. The same cracks in a fiberglass bumper can probably be repaired immediately for a labor cost of $150.00. In most cases, unless the damage is very severe, this means a savings of $400.00 to repair a fiberglass front bumper rather than replacing a urethane bumper.
I also think over time urethane warps a bit. Wavy bumpers on the C3. And, it can be seen with how C5s get that dimple in the urethane on the side where it connects to the glass. You won't have that with fiberglass.
Plastic on the other hand is against anything being applied to it whether it be fillers, paint, repair materials..As with any body/paint process, your prep needs to be spot on. If it isn't, plastic is the most unforgiving. You can take that to the bank
Also, most modern day paints have enough flexibility to be applied to plastic. The manufacturers know that there are more and more cars rolling off the line with plastic parts. In addition the painter also has the option of adding a flex agent if he/she deems necessary.
