Tire pressure warning system
Old Mar 11, 2009 | 10:38 AM
ZR1991's Avatar
ZR1991
Default Tire pressure warning system
In the case of a Corvette that does not have one (say a 2002 ZO6... Wait a minute, that's MY car!), is there a reasonable way of adding a tire pressure warning system. Maybe stock? Or is there an aftermarket that is not an embarrassment?
Any suggestions, any at all (except throwing the car away and getting a coupe) will be much appreciated.
Regards as always.
PS I am a freak about tire balance. I threw away my 1991 ZR-1 system because of the way the sensors strapped around the wheel. I never was happy with the precision of the wheel balance (sometimes I like to go really fast, and once one blew apart from centrifugal force-probably already damaged). But I am aware that just about everything out there now has solved that issue. But I know next to nothing about offerings on complete add-on systems, that's why I am posting.
I really would appreciate any and all ideas and links (I assume there are older posts, but I know this area of technology is changing fast, so I am kinda restarting the discussion if there was one).
Thanks in advance, Arthur in Baton Rouge
Old Mar 11, 2009 | 10:56 AM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
http://www.tirerack.com/accessories/...ELLATPMS&ID=51
Knew these were out there but never heard any feedback here. I'm not positive what they fit without banding.
Old Mar 11, 2009 | 11:00 AM
De_Vette's Avatar
De_Vette
http://www.speedycarparts.com/sku/un..._TPMS409S.html
Old Mar 11, 2009 | 11:57 AM
76texvette's Avatar
76texvette
I did my 04 Z06.
Got the sensors from www.gmpartshouse.com
||--Genuine GM C5 Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 38.80 each
15234846 - nuts – 3.73 each
Total setup of 4 is 186.79 shipped
I had a friend with a Tech-II turn on the sensors.
You could have your dealer do it as well.
Then programmed the sensors with a strong magnet.
They have worked flawlessly now for over a year.
Old Mar 11, 2009 | 03:16 PM
poolboy's Avatar
poolboy
Originally Posted by 76texvette
I did my 04 Z06.
2001-2004 Sensors
other than the sensors themselves, everything else is already in the car - just needs to be turned on.
Old Mar 11, 2009 | 03:25 PM
fireman591's Avatar
fireman591
Do you have working key fobs? if so the receiver is still in the car. The TPS and key fobs use the same receiver. If the receiver is still in the car all you need is the sensors and someone with a Tech II to turn them on.
Keep us posted
Old Mar 11, 2009 | 03:54 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Keep us posted
To Tire pressure warning system
