Help ... 2004 shuts off - wont run
Old Mar 11, 2009 | 07:12 PM
diane fragnito's Avatar
diane fragnito
1st Gear
Default Help ... 2004 shuts off - wont run
Has anyone ever had this problem. The car turns over but when you put it in gear it shuts off. Only 9,000 miles on car - we had it back to the dealer three times already. They installed a new column harness 3,000 miles ago and now its happening again (of course its out of warranty now). Any suggestions?
Old Mar 11, 2009 | 07:23 PM
dobewillie's Avatar
dobewillie
hopefully some one will chime in good luck with a quick fix
Old Mar 11, 2009 | 07:49 PM
RedSoxFan's Avatar
RedSoxFan
Diane, this sounds like the column lock issue, please reference the sticky in the tech section. If this is the issue the dealer fix is a waste of time and money, get an aftermarket column lock bypass and install it and your problems should be over.
Old Mar 11, 2009 | 08:26 PM
dougbfresh's Avatar
dougbfresh
Does the steering wheel turn after you start it? It's most likely the security system. Buy the CLB and REMOVE the Chevy Bypass.
Old Mar 11, 2009 | 09:17 PM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
NO steering lock on a 2004.
Old Mar 11, 2009 | 09:19 PM
bobc997615's Avatar
bobc997615
How new is the battery? Since it's a low mileage '04.
Old Mar 11, 2009 | 09:26 PM
O4-/-C5's Avatar
O4-/-C5
I did not understand your answer.
Old Mar 11, 2009 | 09:59 PM
BlueSkunk952's Avatar
BlueSkunk952
Welcome to the Forum.
Wondering if there are any trouble code stored.
To Help ... 2004 shuts off - wont run
