whats the problem here? PLEASE HELP ME
What kind of dyno? How does the car feel, stronger than it was when stock or worse?
but my buddy that was with me say its fast as crap and way faster befor and he can tell a difference
The number you received as probably 313 rear wheel horsepower. This equates to about 380-385 horsepower at the crank. (If you factor in approximately 18% in drivetrain losses.) It also depends on what kind of dyno they used. Mustang Dyno's read lower than Dynojet Dyno's for the same car... so your numbers may be higher/lower than that by up to 10% or so.
Unless you changed it, your car has a LS1 intake vs. a LS6. It doesn't flow on the intake side like it should with the cam you picked. You might want to upgrade to the LS6, or a FAST intake.
You didn't mention if you had long tube headers. If you are running stock manifolds, you are restricting your flow for the cam you picked. Same holds true of you have stock cats and exhaust.
Seeing that we are on the subject of the cam... it's WAY too big for this application if you don't have the supporting mods. With a stock intake and exhaust, you probably should have gone no bigger than a 224-228 on a 114 LSA. Maybe a 112 LSA if you wanted it choppy. Anything bigger than that, and you are losing low end power while moving the overall power 'band' too high in your RPM range.
One last thing: A 3600 stall is probably going to make your overall HP numbers look low. While it's going to start to engage below 3600 RPM, it will not be transferring full power to the drivetrain until the higher RPM's... and unless you have bumped your rev limiter and shift points to 7000 RPM, you are now limited in the RPM range where you can deliver total power to the wheels.
Total average horsepower and torque (area under the curve) is much more important than any 'peak' numbers you get. Unless you just want bragging rights.
Hope this helps.
Mark
Stock heads and stock exhaust manifolds are going to limit your gains from a cam upgrade.
Keep us posted.
GL
Hope this helps.
Mark
ok i want all the power i can get out of this cam so please tell me what to do and what i need and what i need to tell the shop to do to my car????? like i said i want my all over power!
also i got all my parts from hpe and these are the parts they said i need with this cam so can u guys help me get all the power it suppose to give me
but th car do pull good from 0-120 but after that its not so strong like when it was stock ill have her at 150and 160 and she pulls good
Lets get you a good cold air intake and a FAST 92mm with some larger than stock injectors and for sure some GOOD long tube headers and mid-pipe, Ok.
Call me at the shop tomorrow, if you still want that Nitrous kt, Ok
1-864-268-6820
Mike Yeager
Eastcoast Perf. & Corvette's
1-864-268-6820
1-864-268-6820
Mike Yeager
1-864-268-6820
but guyz im stuck i was jus about to buy these ccw classics which i might still get but i could take dat money and get the parts i need omg guyz i jus dont kno what to do i got the money jus dont kno which way to go.
then later i wanted to get a 408lsx so what should i do but im goin to still use the same cam but im sorry guyz my mind is jus everywhere
