Run Flats
Old Mar 13, 2009 | 02:10 PM
Keppah's Avatar
Keppah
Default Run Flats
I have Gooyear Eagle F1 All Season Tires on 1997 Corvette I purchased.Can anybody tell me if these are runflats?Does it say runflats on tires anyplace?
Old Mar 13, 2009 | 02:33 PM
BostonJoel's Avatar
BostonJoel
The tire companies use other words for run-flat.
I think GY uses EMT (extra mobility tire) and you should find that legend on the tire...possibly in an oval.
Michelin uses ZP for zero pressure.
Old Mar 13, 2009 | 02:38 PM
Oldvetter's Avatar
Oldvetter
The all seasons Goodyears are NOT run flats. Only all season runflats are made by Michilen. But those (Goodyear A/S F1s) are good tires, second only to Goodyear GSD3s, which are summer tires.
Goodyear runflats say "EMT" on the sidewall for Extended Mobility Tire.
Old Mar 13, 2009 | 03:13 PM
killain's Avatar
killain
Oldtimer
My 2003 has exactly that, a plain oval with the letters EMT
Old Mar 13, 2009 | 03:20 PM
BostonJoel's Avatar
BostonJoel
You might want to also check the manufacture date on tires on a 12 year old car. There are a ton of threads on the subject, how to read the date, etc. The risk is that old tires dry out and become a safety hazard.
Old Mar 13, 2009 | 03:41 PM
Oldvetter's Avatar
Oldvetter
Good advice, but I think you will find out that Goodyear A/S F1s are relatively new tires.
Old Mar 13, 2009 | 05:53 PM
Keppah's Avatar
Keppah
Default run flats
Thanks for info.Tires are new.Wasn't sure if they were run flats.Think I will purchase Z06 Tire Inflator Kit.I do have CAA same as AAA here in Canada.
Old Mar 13, 2009 | 09:58 PM
If they do not say EMT on the sidewall, they are not runflats.
Old Mar 13, 2009 | 10:00 PM
csexton's Avatar
csexton
Chuck
To Run Flats
