[Z06] Shorty Headers
Old Mar 14, 2009 | 07:05 PM
MTPZ06's Avatar
MTPZ06
Default Shorty Headers
Anybody running them and pleased with the results?
I have an '03Z and I'm looking to pick up some used shorties (JBA or B&B) if I can find a deal that makes it worthwhile. I know everyone will say go LT, but I'm in CA and I'm tired of owning vehicles that are a PITA to pass smog inspections here...so I'm looking to go with a pair of Shorties that have a CARB EO#.
I've done the search on Shorties, and most comments I see are those that say "go LT" instead. Not an option for me...so I'd prefer to hear from folks running shorties. Any input would be appreciated...Dyno, SOTP, etc.
Old Mar 14, 2009 | 07:32 PM
hotwheels57's Avatar
hotwheels57
There are plenty of people who need to use shorty headers (CA) or went to shorty headers by choice. I live in an area w/o emissions requirements...for now...but it's coming.
For that reason, my choice would also be shorty headers. I've decided on the B&B headers because they are located only 100 miles away. And if emissions does come my way someday, the CARB sticker will be worth it.
In the past whenever someone asks the question, there are always those who say "use long tubes" instead of answering the question. It ends up being a debate. That's fine and that's their choice. But, it doesn't work for everyone. There are plenty of reasons to select shorty headers, especially for a DIY installation by someone who doesn't want to deal with all of the issues of long tube headers.
My only suggestion is to use "jba headers" or "b&b headers" or "shorty headers" as keywords and just be patient reading through the BS to find what you're seeking...
Old Mar 14, 2009 | 08:54 PM
TakeAwayTheFear's Avatar
TakeAwayTheFear
yes California sucks!! but you can go long tubes if you want. changing them back to stock one a year or every other year isnt that bad.
so many people in california have them and get away with them no problem.
just a thought
Old Mar 14, 2009 | 10:45 PM
speedyhawk101's Avatar
speedyhawk101
From what I understand.....Being LSx cars for the last 10 years is that shorty headers are a waste of time and money. Go long tube or not at all. JMHO
Or just move away from the socialist republic of califormia.
Old Mar 14, 2009 | 10:50 PM
hattitude's Avatar
hattitude
I went with the B&B shorty headers. I picked them over the JBA because they were a stepped design with equal length tubes. The JBA weren't equal length tubes.
I mostly went for them to stay CARB compliant, I like the looks of headers vs stock manifolds (got mine jet hot coated), and wanted to offset some of the extra weight my KB supercharger added to the front end.
FWIW...... good luck....
Old Mar 14, 2009 | 11:51 PM
MTPZ06's Avatar
MTPZ06
Pretty much my line of thinking, except I have no plans to go FI. Did you bolt on the shortys before the KB, and did you notice any improvement over stock?
I think I would prefer to go with B&B over JBA as well, but based on everything I read, I don't know if they truly make more HP. I think I can find a better deal on used JBA's than I can on B&B, so if the end result is the same...I'd rater save a few bucks.
Old Mar 15, 2009 | 11:16 AM
hattitude's Avatar
hattitude
Yeah I put the shorty's on first. I thought I detected a subtle difference in the sound from the engine area and thought I felt a slight increase in SOTP torque... but no pre/post dyno or testing.
It could have very easily all been in my head..
But I do like the looks, and there was an obvious difference in the weight....
Old Mar 15, 2009 | 02:57 PM
got2hav1's Avatar
got2hav1
2019 C6 of Year Finalist (performance mods)
Default Shortys
I had JBA shortys on my 03Z. You will notice a change in sound and I could feel some difference in performance. Later had the car tuned and came up with 370/364. Did not have a stock dyno number to compare it to. Later I switched to LG Pro long tubes and made 380/370.
Old Mar 15, 2009 | 09:18 PM
MTPZ06's Avatar
MTPZ06
Based on your numbers, I'd say they were worth something...most likely the 8-10 whp that most mention, if LT's were only worth another 10 hp. Thanks for the input.
Anybody else have similar results from JBA or B&B shorties? So far they sound worthwhile for those that must deal with strict smog laws.
Old Mar 16, 2009 | 01:26 AM
madman91's Avatar
madman91
fwiw myself and two other friends of mine have a set of the bbk shorties and they work great. good fit and finish and they installed very easily. plus they are very affordable and look great, and they DO flow better then the stock manifolds. hope this helps
To Shorty Headers
