fault code on DIC safety column lock
Old Mar 16, 2009 | 06:22 PM
morrja's Avatar
morrja
1st Gear
Default fault code on DIC safety column lock
Has anyone had this code? I recently started my 99 after stored for the winter and it tells me that I need to have it towed to the dealer. This is the first problem I've ever had with this car. It only has 27000 mi. Any help would be greatly appreciated. Thanks, Jeff
Old Mar 16, 2009 | 06:36 PM
dougbfresh's Avatar
dougbfresh
Read the sticky at the top of the tech section-you'll have several DAYS of reading.
Old Mar 16, 2009 | 07:13 PM
jacobsjp's Avatar
jacobsjp
Since you just took it out of storage, I would check your battery. Many times it can just be low voltage.
To fault code on DIC safety column lock
