underhood light
Old Mar 19, 2009 | 06:15 PM
Bronk's Avatar
Bronk
Default underhood light
I have replaced the bulb and checked fuse (#6) as suggested, and still can't seem to fix the problem (light does not come one when hood is opened). Is there a switch or some type of mechanism that supplies power to the light to come on when the hood reaches a certain point in the opening process? This is the next place to look, I guess.
Thanks in advance and to all the replies to my original post
Bronk
Old Mar 19, 2009 | 06:19 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Bronk
Open your hood, stand in front of the car. Down to the left infront of the radiator shroud there is a connection that some disconnect when the car is shown...
Peace
Chip
__________________
..................Click for
Old Mar 19, 2009 | 06:28 PM
fireman591's Avatar
fireman591
Peace
Chip
If it is connected, disconnect it and put a 12 volt test light on it. It should have power. If it does the light might have issues with the level switch mechanism if it has one. I assume it does.
Keep us posted
Old Mar 19, 2009 | 07:38 PM
ljthe2nd's Avatar
ljthe2nd
There is a switch built into the light, it is not replaceable you have to buy a new light, As fireman591 has suggested check to see if you have power but you would be better off checking both places where it disconnects down by the radiator shroud and at the bulb.
Old Mar 19, 2009 | 07:55 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Mine blew the #2 fuse in the passenger footwell...
Old Mar 19, 2009 | 08:11 PM
dobewillie's Avatar
dobewillie
good info
Old Mar 19, 2009 | 08:13 PM
Rossi396's Avatar
Rossi396
Same for me...Check number 2...
Old Mar 20, 2009 | 11:47 AM
Bronk's Avatar
Bronk
Default # 2 fuse it is!
Thanks, guys! I checked the connection by the radiator shroud as per directions - thanks WILFULONE, and no "juice". I pulled the #2 fuse, and it was blown. Thanks QUICKSILVER Z and ROSSI396! Thanks to all Forum members who helped out with suggestions!
Bronk
Old Mar 20, 2009 | 02:38 PM
Allzwell's Avatar
Allzwell
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Way to go ... glad you found the problem
Old Mar 20, 2009 | 10:53 PM
Quick Silver Z
Bronk
Let there be light!
To underhood light
