Question on Corvette Alternator...
Old Mar 19, 2009 | 11:26 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Default Question on Corvette Alternator...
My 2002 C5 has some kind of clutch on the alternator, What the heck does it do and when does it do it...lol
Thanks in advance.
Bill
Old Mar 19, 2009 | 11:40 PM
nextime's Avatar
nextime
Pictures?
Old Mar 19, 2009 | 11:42 PM
Mr.Bill's Avatar
Mr.Bill
Here you go...
Old Mar 19, 2009 | 11:45 PM
nextime's Avatar
nextime
Looks like a fancy end cap to dress it up.
Old Mar 19, 2009 | 11:49 PM
Mr.Bill's Avatar
Mr.Bill
I was told it was a clutch, But he didn't know how it worked.
Old Mar 20, 2009 | 09:11 AM
Greenvette's Avatar
Greenvette
Intermittent Accessory Drive Rumble During Garage Shift (Install New Generator) #99-06-04-029A - (11/29/2000)
Models: 1997-2000 Chevrolet Corvette
with 5.7 L Engine (VIN G -- RPO LS1)
and 4L60-E Automatic Transmission (RPO M30)
This bulletin is being revised to update the correction procedure. Please discard Corporate Bulletin Number 99-06-04-029 (Section 06 -- Engine).
Condition
Some customers may comment on an intermittent accessory drive rumble noise when performing a garage shift and/or during parking lot maneuvers, such as turning the steering wheel to the lock position. This noise may also occur when turning on the air conditioning at idle conditions.
Cause
Engine idle speed may drop below 600 RPM while performing a garage shift, turning the steering wheel to the lock position, or turning on the air conditioning. This noise may be amplified by a large rate of change in engine RPM. This condition can also be aggravated by different low engine RPM driving conditions.
Correction
A new Generator with Decoupler Pulley and reduced damping Accessory Drive Tensioner was implemented for all Corvettes with automatic transmissions at 2001 SOP (Start Of Production). The generator with decoupler pulley is used only on Corvettes equipped with an automatic transmission. The reduced damping accessory drive tensioner is used on all 2001 Corvettes.
The new decoupler pulley generator and tensioner assembly should be used to service 1997-2000 Corvettes with automatic transmissions that exhibit the idle rumble noise. Refer to the Engine Electrical and Mechanical sub-sections of Engine in the Service Manual for generator and tensioner replacement.
Old Mar 20, 2009 | 09:22 AM
bucwheat's Avatar
bucwheat
A/C has a clutch,that what you are talking about?
Old Mar 20, 2009 | 12:27 PM
Mr.Bill's Avatar
Mr.Bill
Decoupler Pulley is kinda like a clutch....
Thanks for the info, Now I know what it is and what it does....lol
Bill K
Old Mar 20, 2009 | 02:23 PM
PETE O.'s Avatar
PETE O.
Ha, Ha, that made me run out to the garage and look at my `01. Sho nuff, it has one. I'd never noticed it. Clever idea, I'd say.
Old Mar 20, 2009 | 03:55 PM
Robls6's Avatar
Robls6
Corvettes have automatic transmissions???
Old Mar 20, 2009 | 03:59 PM
Mr.Bill's Avatar
Mr.Bill
You bet they do, And some are bad a$$... Don't under estimate an A4....
To Question on Corvette Alternator...
