Need Alignment Spec Recommendations
Old Mar 20, 2009 | 08:41 AM
VETSTYL's Avatar
VETSTYL
Default Need Alignment Spec Recommendations
Putting new tires (Generals) in stock size on this weekend and I also know I need an alignment. I am lowered on stock bolts, Z06 sway bars with metal end links and Bilstein HD shocks. What specs would you recommend that I get?
VETSTYL
27 Year Army VET(styl)
Old Mar 20, 2009 | 08:50 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
VETSTYL
Get a Z06 4 wheel alignment, anything more for the street is a waste of good tires...
Peace
Chip
__________________
..................Click for
Old Mar 20, 2009 | 09:24 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Print these out, and take them to your alignment shop. Use ADVANCED STREET for Z06 specs.
http://www.vbandp.com/instructions/h...ruct/align.htm
Old Mar 21, 2009 | 12:24 AM
JEEP/C5's Avatar
JEEP/C5
can you really tell a difference in handling between the normal c5 vs. z06 specs? I know the z06 will wear tires slightly more but is it worth it?
Old Mar 21, 2009 | 02:16 AM
VETSTYL's Avatar
VETSTYL
Default Advanced Street
Thanks for the info- I'll take it in with me.
Old Mar 21, 2009 | 07:00 AM
RonJ's Avatar
RonJ
My 01 never sees a track, it's all street driving and much of that straight driving. I found that the inside of the front tires wore badly due to too much negative camber which was within specs.
For street use, I'd keep the camber on the conservative side, -.2' is lots!!
My two cents ..... RonJ ....
To Need Alignment Spec Recommendations
