Headlight "Clear/diamondcut" lens?!
Old Mar 20, 2009 | 04:03 PM
Maites's Avatar
Maites
Default Headlight "Clear/diamondcut" lens?!
Ok, so I have been looking into the HID plug n play world. Obviously there is enough info on the forum for me to go nuts on everyone's different opinions. Anyhow, I remember seeing a clear headlight lens as a replacement for the stock. 1) does anyone know where to find this lens (i searched with no luck) 2. Will this enhance the HID's output? Or could it cause problems for other drivers? glare? I just dont like the look of the stock lens. Anyone have any ideas? Thanks all
Have a great weekend
Old Mar 21, 2009 | 01:14 PM
Maites's Avatar
Maites
Anyone?
Old Mar 21, 2009 | 02:18 PM
magnetized's Avatar
magnetized
St. Jude Donor '09
Haven't heard of anything like that, only custom headlights I know of are non pop-up projectors, pop-up projectors, and euro-spec headlights.
Old Mar 21, 2009 | 02:20 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Mar 21, 2009 | 10:04 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Here you go but I don't think you will like the price.
http://www.corvettegarage.com/produc...-corvette.html
Old Mar 21, 2009 | 10:38 PM
jrprich's Avatar
jrprich
Actually those are ACA full headlight assembly replacements with built in HID projectors and ballasts.
The OEM "lens" cannot be replaced unless you were to actually saw off the front of the headlight capsule and replace the original lens with clear lexan.
This is a tedious process that bothe Radioflyer and I have both done in the past......I would not recommend trying this.
And no, I doubt it would improve your HID pattern.
Old Mar 21, 2009 | 11:53 PM
Maites's Avatar
Maites
interesting.... alright well i guess i will go the cheap route for now and pick up some plug n plays and call it a day...As long as I can see at night!
Old Mar 22, 2009 | 12:05 AM
Norcalzosix's Avatar
Norcalzosix
CIBIE ~ Ask for Gunther 562-699-8887... This company imports the 'Clear Glass Euro Headlights' directly from Germany. I'm rocking those with 8000 HID's and trust me you will be able to see at night!
Old Mar 22, 2009 | 10:19 AM
Nepthalim's Avatar
Nepthalim
These are nice but I just can't get pass the price of them...sigh...maybe one day!
Old Mar 22, 2009 | 11:39 AM
Maites's Avatar
Maites
mind if I ask what they cost? Do you have link?
Old Mar 22, 2009 | 11:47 PM
Norcalzosix
I dont have the link but you can look up the site on the web.. Its Aardvark International or something. If you call the number I provided Gunther can take care of you for sure. The cost for the lenses alone is about 89.99 each.. So 180 for both and then you purchase your HID kit...
Old Mar 22, 2009 | 11:55 PM
jdmvette's Avatar
jdmvette
Night Owl for life
post some pics of the lights you're sporting.
Old Mar 23, 2009 | 12:22 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Clear lenses will not help any with glare or pattern. You'll get more output, but it's the same aweful pattern...
this is how i know:
Your high beam pattern though is like a miniature sun:
The T84 Euro housing is cleaner cut, but still not completely clear:
(euro is on right)
The only way to get an even powerful output without blinding other drivers is to go with projectors.
These are the projectors on my car:
and these are the "light cannons"
Old Mar 24, 2009 | 09:48 AM
B-Vette's Avatar
B-Vette
Great info guys, thanks!
Old Mar 24, 2009 | 11:27 AM
Maites's Avatar
Maites
thanks for all the helpful input. I was looking for the clear lens simply for looks, not light output. Although I was curious if output would be affected. I think the clear lens just gives a more modern look (i realize it probably doesnt matter at all when the lights are on anyway). Anyhow, i may end up going this route and I'll keep you all posted. thanks again for all the helpful info
Old Mar 24, 2009 | 12:12 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
In that case. It is possible to make your own: (estimated cost: $35-40 plus the huevos to cut up your OEM headlights)
1) use a dremel to cutaway the OEM lens (as seen in my first pic)
2) use a sanding station to ensure the edges of the remaining part of the lens is flat and even
3) make a template from the rest of the lens. Use this template to cut
a sheet of 1/4" lexan to the shape of your lens.
4) For added "coolness" bevel the edges of the lexan piece, then use a butane or propane torch to heat up the sanded section to the point where it just begins to melt. This will give you a super-smooth glass-like edge
5) (this is the part I was never able to do) Find an ultra-high-strength clear adhesive to secure the lexan piece to the lens. Let dry then re-install.
Old Mar 24, 2009 | 07:11 PM
JohnnyB's Avatar
JohnnyB
(euro is on right)
The Euro lens looks smaller than the OEM. Does it fit perfectly in the stock opening? I'm thinking about going with these and halogen bulbs.
Old Mar 24, 2009 | 07:54 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
They're the same size, the Euro was sitting at a different angle. I'm actually planning on selling this set. It comes with the relay harness and PIAA 130W halogen bulbs (the next best thing to HID)
PM me if you're interested.
Old Mar 25, 2009 | 12:39 AM
Norcalzosix
Radio you always have the right things to say when it comes to lighting!
To Headlight "Clear/diamondcut" lens?!
