[Z06] Trunk Latch
Old Mar 21, 2009 | 02:23 PM
BRISLS1's Avatar
BRISLS1
St. Jude Donor '11, '14,’19
Default Trunk Latch
My recently acquired Z16, has a problem with the trunk latch. The motor unlocks the trunk, and I can pick the whole thing open reaching between the body panel and the trunk with my fingertips.
Anybody else have this issue? I know the motor is moving something mechanical because I can see it move with the trunk lid open.
My old C5 did this same thing but would eventually open the hatch with repeated clicks of the clicker.
Thanks!
Old Mar 21, 2009 | 03:10 PM
Chris Stewart's Avatar
Chris Stewart
Sounds familiar and a common problem. A forum search will reveal many threads on this. I took the easy way out and ordered from c5trunkpopper.com and I'm very happy with the results.
Old Mar 21, 2009 | 03:49 PM
vsocks1's Avatar
vsocks1
Just unlatch and with all windows rolled up closed & shut a door! Pops right up!
Old Mar 21, 2009 | 04:43 PM
enigma94's Avatar
enigma94
hahaha, Ive found this out as well. If i cant get my finders in i will use the tip of the key to pull it up a bit.
Old Mar 21, 2009 | 08:52 PM
Stevo92z28's Avatar
Stevo92z28
I found this:
http://www.corvettemods.com/servlet/Detail?no=40
Have not purchased it yet. My Z has the same issue. I have skinny fingers.
Old Mar 21, 2009 | 09:41 PM
James92's Avatar
James92
You guys need to rebend the spring that actually pops up the lid, it gets fatigued after a while and needs to be rebent.
Old Mar 21, 2009 | 10:05 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Tell me more about this spring. I need to check into this a little closer.
Old Mar 21, 2009 | 10:32 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
You dont need the spring. Open your trunk and theres a spring in the latch motor thats probably bent doen over repeated use. Take some pliers and bend it back up and the problem is solved.
It looks like a round metal bar going across the opening where the trunk latch goes (you may have to push the carpet away from the mechanism to see it). Bend that round rod (it's actually the spring that raises your trunk) back up.
Old Mar 21, 2009 | 10:40 PM
Stevo92z28's Avatar
Stevo92z28
Good deal, will have to check this out tomorrow.
Old Mar 21, 2009 | 10:59 PM
tremor1's Avatar
tremor1
Had the same problem when I bought mine in December, rebent the spring as described and it fixed mine. Works great now.
Old Mar 21, 2009 | 11:34 PM
Eddie 70's Avatar
Eddie 70
This sounds like one of the first things I will get after tomorrow when I get to moving around. Will post my results back tomorrow.
Old Mar 21, 2009 | 11:35 PM
ls1impulse's Avatar
ls1impulse
I found this:
I just bought this the others day, I'll be sure to update with how it works!
Old Mar 22, 2009 | 12:58 PM
James92's Avatar
James92
I was talking about the spring in the original latch, not the aftermarket helper spring.
Old Mar 22, 2009 | 09:58 PM
Millenium Z06
Moderator
I was referring to Stevos post
Old Mar 22, 2009 | 10:26 PM
Drug Delivery's Avatar
Drug Delivery
I did the earlier today and it's works. Saved me $15.
Old Mar 22, 2009 | 11:28 PM
James92's Avatar
James92
ah, okay.
Old Mar 22, 2009 | 11:29 PM
James92's Avatar
James92
You're welcome.
To Trunk Latch
