[Z06] torque spec questions
Old Mar 22, 2009 | 07:26 AM
chris__2007's Avatar
chris__2007
Default torque spec questions
doing some spring cleaning on my old mans car. i ended up pulling the wheels/calipers/rotors to clean.
searching here i found and wanted to confirm:
caliper mounting bracket 125lb/ft front and rear
caliper bolts 23lb/ft front and rear
do you guy's loctite the mounting bracket bolts?
lugnut torque?? i can't find it but i'll guess 80lb/ft is in the area.
appreciated, i want to get his car done so i can get to work on mine.
i need a service manual for a z asap. helm the best source?
Old Mar 22, 2009 | 08:52 AM
LO PHAT's Avatar
LO PHAT
This link on Elite Engineering's website may help you out:
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
Great information, great company, and great products...
LO PHAT
Old Mar 22, 2009 | 09:53 AM
chris__2007
LO PHAT
may? that page is getting printed out and hung up in the shop! appreciated taking the time to answer questions that were asked many a time.
Old Mar 22, 2009 | 12:58 PM
jerboa's Avatar
jerboa
St. Jude Donor '14-'15
Proper torque on the Z06 lug nuts is 100 lb ft per the factory manual.
Old Mar 23, 2009 | 09:29 PM
TEXHAWK0's Avatar
TEXHAWK0
Note: bleeder screw is inch-pounds, not ft.-lbs.
To torque spec questions
