Unscrew the 4 plastic pieces on the back wall. Use a small screwdriver to pop out the plastic retainers in the botton side of the horizontal plastic trim under the rear window. Pull that trim piece forward till it pops out. Remove the 2 plastic clips under the trim piece you just removed. Pop open the plastic covers at the top of the seat belts. Remove the bolt holding each seat belt at the top. Look for 1 plastic clip on each side that holds the side window weatherstripping to the plastic trim piece. From the front edge, push the trim pieces towards the center of the car. Go back to the trunk and pull the trim pieces on the rear part of the wheel wells towards the center of the car. At this point, the carpet will be held in place only by velcro, or because it's tucked under or around something, so just start pulling it out.
Bless you my son!
Are the reear speakers attachhed to the car or to the plastic panel
