Difficult to Turn Wheels Left or Right
Old Mar 22, 2009 | 09:09 PM
67silverandblack's Avatar
67silverandblack
Default Difficult to Turn Wheels Left or Right
Trying to parallel park the steering wheel was difficult to turn left or right. It also made a light screeching noise. While moving it seems to drive normal. Just at low speeds or a stop. Power steering fluid was not low so I did a search & came across changing the differential fluid. Is that what i need to do? I am the 2nd owner so I am not sure if it has been done before, but I have 50,000 miles.I don't know much about cars so I figure out how they are related.
Is that a symptom of dirty fluid, hard to turn the wheels left or right while at a stop?
I assume I can bring it to any shop to get it changed? I looked underneath & it didn't seem very easy to do.
Old Mar 22, 2009 | 09:19 PM
Hammer99's Avatar
Hammer99
I am not an expert, but diff. fluid does not sound right to me. I am thinking power steering pump is going. Just my .02
Old Mar 22, 2009 | 10:14 PM
67silverandblack
Of course now I can't find the link. I guess I will have to keep searching. I sure have been having a hard time searching here lately. I guess the key words I have been using are too general.
Thanks for the suggestion.
Old Mar 22, 2009 | 10:52 PM
Carcass's Avatar
Carcass
Sounds like the belt tensioner may be weak,or the serpentine belt is worn.(hardened,so it's not "grippy" anymore)
Screeching would be the belt slipping when a load is put on the steering pump.(car not moving=big load on pump when turning wheels)
Worst case scenario,as Hammer99 suggested,is the pump is toast.
I'd check out the cheap stuff first...
To Difficult to Turn Wheels Left or Right
