[Z06] shifting into 2nd gear
Old Mar 24, 2009 | 02:45 PM
vwtdi's Avatar
vwtdi
Default shifting into 2nd gear
Once in a while when going from 1st into 2nd gear from a stop, the shifter doesn't want to go in (almost like its locked out by the gate). If I go to 3rd, then back to 2nd, it will engage without a problem. Any ideas whats going on?
Old Mar 24, 2009 | 02:47 PM
ls1impulse's Avatar
ls1impulse
Originally Posted by vwtdi
once in a while when going from 1st into 2nd gear from a stop, the shifter doesn't want to go in (almost like its locked out by the gate). If i go to 3rd, then back to 2nd, it will engage without a problem. Any ideas whats going on?
cags? does the cluster illuminate a 1-4 shift light?
Old Mar 24, 2009 | 02:49 PM
ls1impulse's Avatar
ls1impulse
And your location says Mt. Joy, is that Mt. Joy township? As in Gettysburg area?
Old Mar 24, 2009 | 02:51 PM
vwtdi's Avatar
vwtdi
East Donegal Twp in Lancaster County, about an hour NE from Gettysburg, halfway between Lancaster and Harrisburg.
I never noticed a 1-4 illumination but I could be wrong. I'm assuming this will come up on the HUD? Was the skip shift eliminator not installed on my car? Can I tell? I only have this problem going from 1st to 2nd and I'd say I always shift at about the same RPM...sometimes with no trouble, I'd say it happens once out of 25 times.
Old Mar 24, 2009 | 03:30 PM
Zidane's Avatar
Zidane
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Happens to me EVERY time trying to go from 6th to 5th...no idea what it is.
Old Mar 24, 2009 | 03:34 PM
TEXHAWK0's Avatar
TEXHAWK0
CAGS locks out 3rd and 2nd, so that is not likely the problem.
I have problems going to 2nd sometimes if I shift at a low RPM, and too slowly. A little higher RPM and quicker on the shifter and never a problem.
Even with CAGS bypassed, the dash light will still come on, so that is not a good test of whether the system has been bypassed.
IF something is wrong in the transmission, it could be the synchronizers are not working.
Changing transmission fluid "might" help.
Old Mar 24, 2009 | 05:19 PM
edaniel7's Avatar
edaniel7
Happens to me when trans. fluids are cold and/or with slow granny shift. Warm fluid, a little RPM and good fluid are a start towards "happy" synchros !!~
Old Mar 24, 2009 | 05:33 PM
ls1impulse's Avatar
ls1impulse
True, but if you play around going for 2nd for a second or two, by the time you get to 3rd you will have probably gotten out of the CAGS rpm range.
Also, the plug and play CAGS eliminators leave the illuminated light on, but I beleive the illumination can even be tuned out if done by HPT/EFIlive etc. though I may be wrong.
Old Mar 24, 2009 | 06:49 PM
stig-zzz's Avatar
stig-zzz
yup with a tune it all can be tuned out light included
Old Mar 25, 2009 | 03:45 PM
stock z06's Avatar
stock z06
my mail order chuck cow tune took care of that little demon
and your correct NO more light either!
To shifting into 2nd gear
